stuck brake bolts
Old May 27, 2002 | 07:23 PM
Ryan77's Avatar
Ryan77
Default stuck brake bolts
I'm in the process of swapping on a set os SSBC calipers and hoses, the fronts went on no problem in under an hour, but the mounting bolts on the rear calipers just won't move :mad . Any advice?
Old May 27, 2002 | 11:26 PM
ROD NOCK's Avatar
ROD NOCK
Default Re: stuck brake bolts (Ryan77)
Try some PT Blaster penetrating oil, let soak o/nite, then a 4 ft pipe over a 1/2 in drive breaker bar. Good Luck -Rod :chevy
Old May 27, 2002 | 11:28 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Heat! I had to use a propane torch on mine to get them to budge. Heated the bolt head for a couple minutes and it broke free easily. :yesnod:
Old May 27, 2002 | 11:43 PM
JB's Avatar
JB
St. Jude Contributor
Default Re: stuck brake bolts (BSiegPaint)
The PB Blaster is marvelous stuff, far better than WD-40. I think I'd give it some time to work before I'd get the long pipe--I'd be terrified I'd sheer the bolt off and really be screwed! Heat's an excellent suggestion, though be aware that brake fluid will burn!
JB
Old May 28, 2002 | 12:19 AM
Stevo81's Avatar
Stevo81
Blaster. Time. Heat. Caution. Prayer.
Old May 28, 2002 | 12:21 AM
Tom73's Avatar
Tom73
Ryan,
I had one bolt on my rears that would not let go no matter what I did. Ended up spliting the caliaper and then drilling the bolt. Made a hole down the center, then the bolt let go.
tom...
Old May 28, 2002 | 02:09 AM
bigvette1's Avatar
bigvette1
Had both rear sides like yours. I soaked the bolts with PB overnight and used an impact wrench with a quality 6 point air impact socket and they broke free after a couple of hammers. Regardless of method, soak them. I for one am very leary of the blue flame wrench around the gas tank.
To stuck brake bolts
