Stumped or stupid
Old Jul 14, 2012 | 08:26 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Default Stumped or stupid
My fan switch works fine in all speeds..................but only when one or the other or both doors are are open. It seems the fan switch control only gets power to operate the blower when the door ajar switch is activated when the door is open. Press in on the switch when the door is open of course and the fan shuts off in any setting of the fan switch. No, I haven't cut or spliced into the fan switch wires or door ajar warning switch. I did remove the AC condensor and piping forward of the VIR over the winter. Now I have this problem. I looked at the wiring diagrams in the 1974 FSM to no avail. I own a 1976. Any ideas on where to start looking for the fault?
Old Jul 15, 2012 | 07:54 AM
Roco71's Avatar
Roco71
The only thing that I can do to help is to give you a bump TTT. hopefully someone can help.
Old Jul 15, 2012 | 08:10 AM
BB72's Avatar
BB72
You lost a ground somewhere, my wipers did that once.
Old Jul 15, 2012 | 09:24 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
How would it work if there was no ground? It does work but as I said, the door needs to be open. What has me baffled is that I don't see any electrical relationship between the door ajar button and the fan circuit other than they are both 12V and need a common ground i.e. the chassis. The battery was disconnected all winter and I had the wiring for the starter motor and alternator disconnected and removed the AC condensor, compressor and tubing/hose forward of the VIR. When I reconnected the battery, the fan doesn't operate properly. I'm also having a problem with my amplifier. It cuts power off at very low volume levels rendering it useless for listening. The trouble shooting guide for the amp says its most likely a grounding problem. The amp is directly connected to the negative terminal of the battery. The sound system also worked perfectly until I reconnected the battery after the winter. Could there be a chaffed wire causing all these problems?
Old Jul 15, 2012 | 10:13 AM
BB72's Avatar
BB72
[QUOTE=resdoggie;1581318316]How would it work if there was no ground?
I didn't see a connection between the wipers and the door switch, I opened my door and the wipers worked. Go figure. A ground wire was off somewhere, I didn't fix it, someone else did.
Old Jul 15, 2012 | 10:53 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Oh, it didn't click in that your wipers worked with the door open similar to my fan. Wish you had fixed it yourself for the exact answer. It seems more like the door ajar switch is acting as the on/off power for the fan switch vice a grounding problem. Just can't get my head around how that can be. I'm sure the fix will be something easy but as I said, everything works fine, just not the way its supposed to power on and off. Hence, stumped so far.
Old Jul 15, 2012 | 11:18 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by resdoggie
...What has me baffled is that I don't see any electrical relationship between the door ajar button and the fan circuit...
There isn't one.
My advice would be to take another look at what you did over the winter. Based on what you posted, things were fine until that point.
Old Jul 15, 2012 | 11:35 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
There isn't one.
Hence, stumped. But there is a relationship now! But how?
Old Jul 15, 2012 | 11:55 AM
scottyp99's Avatar
scottyp99
I think you are going to have to get your hands on a wiring diagram and physically bird-dog the wiring to figure this one out.
Keep the shiny side up!
Scott
Old Jul 15, 2012 | 01:33 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
I was hoping a forum electrical guru could explain how the door ajar switch is acting as an on/off switch for the fan switch. Then, I could take it from there, hopefully. I haven't spliced into any wires related to the fan or the door ajar circuit afaik. I spliced into the dash illumination circuit to connect the aftermarket stereo. I have the console apart and right side dash pad looking for clues but all appears normal.
Old Jul 15, 2012 | 02:48 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The blower motor ground is the same ground the wipers are on... Are the wipers working?
But.. the best way to check this is to run an independent ground to the blower motor housing and see if the motor works.
The grounding circuit being used is the white wire ground on the courtesy lamps. But this same ground can be found at the hood opening alarm switch which is right out there above the blower motor. There is a Jamb type "alarm" switch mounted on a bracket right at the firewall. I suppose it is possible someone needed a ground and thought that this was a good one not knowing it was only ground when the switch was open.
So, I'm wondering if maybe someone didn't splice in on that white ground thinking it was just a normal ground.. it isn't.
Willcox
Old Jul 15, 2012 | 03:03 PM
wombvette's Avatar
wombvette
He had the starter wires off, probably didn't hook up the ground wire or has it on the positive side of the starter.
Old Jul 16, 2012 | 11:27 AM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Willcox
I do all my own work with few exceptions such as wheel alignments. I will try your suggestion of an independent ground to the blower motor housing. Thanks for a starting point to begin troubleshooting.
You may have something here. The starter motor wires were off for several months so when I reconnected them the two smaller sets of wires could have been reversed. The cars starts fine and all other systems seem to be fine with the exception of the stereo amplifier. But if they were reversed, what other effects would this have? Would the car even start?
I'll get back at it soon and report back. Thanks to everyone for suggestions thus far.
Old Jul 16, 2012 | 12:12 PM
'75's Avatar
'75
The small ground wire at the starter also grounds the wiper motor.
Old Jul 16, 2012 | 02:23 PM
wombvette's Avatar
wombvette
Wiper motor and blower motor, and if you hook it up to the hot wire at the starter, it feeds 12V back through the wiper and blower, which causes some weird $#!T.
Old Jul 16, 2012 | 03:12 PM
Peterbuilt's Avatar
Peterbuilt
This BLACK wire that is connected to the starter bolt is the ground for the wiper and blower motor, is this how you connected it?
76 Schematic:
http://www.vetteprojects.com/bmv/mis...tte%201976.pdf
Also the black wire on the temp gauge is the center console ground, check that it connects from the temp gauge to the left side bird cage just above the bottom of the dash.
Old Jul 19, 2012 | 10:00 PM
Brown78's Avatar
Brown78
I just change my starter and I had 1 black wire about 12ga. and it was connect to the negetive side of the sileniord. I do know there isn't a stock wire connected to that bolt. That wire is a ground for something else, after market.
To Stumped or stupid
Old Jul 19, 2012 | 11:25 PM
wombvette's Avatar
wombvette
What?
Negative side of the solinoid?
That black ground wire is on every one ever built.
Old Jul 20, 2012 | 10:35 AM
...Roger...'s Avatar
...Roger...
If your referring to the picture in the above post,the 14 g black wire on the starter bolt is standard from the factory (as wombvette stated)up through approx 76.
Your 78 should have the same wire but connected to one of the bellhousing bolts just behind the starter.
Not sure what you mean by 12 black connected to the "neg side" of the solenoid. Its possible your referring to the fusible link which should be connected to a heavy red wire or 2 depending on what has been done over the years,but it should be connected to the large pos post of the solenoid.Maybe you can confirm what you meant.
Old Jul 20, 2012 | 12:19 PM
Big2Bird's Avatar
Big2Bird
Word of advice from a 57 year old IBEW guy. ANY time you have ghosts, things that should not be that are, suspect a loose/bad ground first. The alternate power paths do strange things.
Lose a ground on a tail light on these cars, and do do happens.
In the power industry, loose nuetrals are ALWAYS suspect. If you turn on a porch light, and your TV goes off, you have lost a nuetral/white wire splice somewhere.
