stumped
Old Jul 15, 2012 | 03:35 PM
colliedogg's Avatar
colliedogg
Default stumped
77 corvette engine runs rough,the distributor was junk so I put in a new one and new wires.I have disconnected all the vacuum lines but it made no difference still has an intermittent miss all rpm's any suggestions? engine has 7k, also readjusted valve lash. recently when I tap the gas a couple times I can get a backfire thru the carb. ?
Old Jul 15, 2012 | 06:14 PM
scottyp99's Avatar
scottyp99
Double check firing order.
Keep the shiny side up!
Scott
Old Jul 15, 2012 | 06:59 PM
'75's Avatar
'75
Scott
18436572
Old Jul 15, 2012 | 08:21 PM
KevinK's Avatar
KevinK
Next check are spark plugs. I went with accell shorty style plugs, only to realize they were the wrong ones, too short to get into my cylinder heads. After the spark plugs,the next check area is fuel pump/filter. Your problem is either timing, or fuel delivery, IMO.
Old Jul 15, 2012 | 08:23 PM
KevinK's Avatar
KevinK
If fuel filter (2.50)is not the issue, run it at night, pop the hood, and look for flashes in the boot area...could be bad arch over.
Old Jul 15, 2012 | 08:32 PM
colliedogg's Avatar
colliedogg
firing order is fine,I have checked every thing I can think of. it starts fine just has an intermittent miss at idle and up, tends to run hot even with a 160 thermostat radiator is fine plenty of flow starting to think the motor got put together one tooth off on the timing chain only thing that makes sense, really gutless secondary's open really slow,or carb with a vac leak I cant find,this one has me going in circles. only back fires lightly one time thru carb when I romp on it let off and do it again? brand new plug wires good ones. plan on replacing Q-jet with new carb suggestions?
One plug was wrong one, replaced it no help. will check fuel pressure tomorrow.
Old Jul 15, 2012 | 08:45 PM
'75's Avatar
'75
How's the timing, have you checked the mechanical advance?
Old Jul 15, 2012 | 08:54 PM
colliedogg's Avatar
colliedogg
brand new distributor I would think its close. but thats an easy check so I will give it a whirl
Old Jul 15, 2012 | 09:06 PM
northern77's Avatar
northern77
How about trying a leak down test with some carb cleaner?
Old Jul 15, 2012 | 09:14 PM
colliedogg's Avatar
colliedogg
tried propane around the carb no difference will try carb cleaner next week if I have time,working 10's next week till further notice.
To stumped
