pop up lights
Old Jul 15, 2012 | 10:13 PM
snwbrdjunky93's Avatar
snwbrdjunky93
Default pop up lights
I have an 81 corvette with the pop out lights which do not seem to pop out. I recently put an aftermarket carb in the car however the light didn't seem to work before either. also there are two 1/4 inch hoses laying on the motor and i was told that I could patch one of them into the power brake assist hose on the carb is that correct.
Old Jul 16, 2012 | 04:39 AM
dgood's Avatar
dgood
the WILLCOX corvette website has diagrams for all the hose routing. That will get you in the right direction. THey also have a troubleshooting guide.
Old Jul 16, 2012 | 09:53 AM
Roco71's Avatar
Roco71
What kind of carburetor are you using? I would source vacuum for your P/B from the carburetor base if so equipped if not directly from a vacuum port in the intake manifold. Any chance of a photo?
Old Jul 16, 2012 | 10:08 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Order the assembly instruction manual (AIM). Main vacuum system supply line should come off a fitting on the manifold between the rear of the carburetor and in front of the distributor. If you have auto trans, the vacuum for the modulator will also come from this fitting.
Vacuum for the power brakes runs from a fitting in the base of the carburetor and over to the booster. Nothing should be on this line other than the booster.
AIM shows both.
Old Jul 16, 2012 | 04:01 PM
snwbrdjunky93
I will get a picture today thanks for the advice and the carb is an edelbrock 1406
Old Jul 16, 2012 | 04:08 PM
Roco71's Avatar
Roco71
That carb has a port in the back of it just for a P/B booster. If not used and left unplugged your car will idle rough (to say the least)
Old Jul 16, 2012 | 04:15 PM
Roco71's Avatar
Roco71
This may help you some
http://www.edelbrock.com/automotive_...406_manual.pdf
Old Jul 17, 2012 | 03:39 PM
snwbrdjunky93
http://s1168.photobucket.com/albums/...y93/?start=all
Those are some pics i took. there is a vacuum hose diagram that i found under the hood the two random hoses are the black/white line and the orange/white line. I cannot seem to figure out where or what the A/CL is and tips.
Old Jul 17, 2012 | 03:57 PM
MelWff's Avatar
MelWff
the a/cl is the air cleaner and that diagram is only the emissions hoses you have to go the wilcox sites diagram list to find all the hoses for your headlight system
Old Jul 17, 2012 | 04:11 PM
Peterbuilt's Avatar
Peterbuilt
How to troubleshoot you headlight system:
http://www.corvette-101.com/vacuum.htm
Old Jul 17, 2012 | 04:35 PM
Roco71's Avatar
Roco71
I apologize for not reading your question correctly. Do not source vacuum from the power brake booster. Your head light should source vacuum from a manifold vacuum port only.
Old Jul 17, 2012 | 09:18 PM
kdf1986's Avatar
kdf1986
You need to look at some of the manuals and diagrams others have provided. If the car is original many of the headlight vacuum lines will be color coded. You need to trace these to there connections and compare that to the diagrams.
On the 80-82 corvette there is a coffee can sized canister in between the headlights. This is a vacuum reservoir to help with the headlights. Check that this is still in place and the vacuum lines are connected. Its all part of the checking for the system back to the source.
kdf
Old Jul 17, 2012 | 09:30 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Look at the hose's you have laying around and see if there are any color marks on them. Then ID where they come from and you should be able to make corrections from the picture below. Once you have the hoses in the correct place then see if they work. If not.... Post back and we'll walk you through how to test the system.
Old Jul 17, 2012 | 09:34 PM
superdave269's Avatar
superdave269
I found this link to be very helpful back when I was learning about the vacuum system.
http://www.corvette-101.com/vacuum.htm#actuator
Old Jul 18, 2012 | 05:07 PM
snwbrdjunky93
So my basic question is where on the carburetor would I connect the vacuum hose that the diagram says should be on the carb and also how do I find the air cleaner what am I looking for.
Old Jul 18, 2012 | 09:25 PM
0Willcox Corvette
Former Vendor
There is a fitting on the back of the intake manifold.. not on the carb.. I'll post you a picture tomorrow..
Old Jul 21, 2012 | 07:55 AM
LannyL81's Avatar
LannyL81
The disconnected hoses look like they are from the charcoal canister and originally went to the carb. The Edlebrock carb you have probably does not have the port for these.
The vacuum port for the headlights comes off the intake manifold and appeas to be there....the hose that make a 90° turn between the carb and the distributor...
Follow this hose and the Wilcox diagram.
You will likely find several hoses that no longer fit tight on their connectors. Also check the canister in the nose for a hole caused by rust. The expensive parts are the vacuum relays and the headlight vacuum motors. Perhaps you will just find a "witch's hat" is leaking.
If you do find it is one of the headlight vacuum motors be advised that when you order a replacement that for years 80-82 there was a change that is seldom noted. If you need a right side - order a left side, a left side - order a right side.
Why?
Because Chevrolet switched the inlet port...take a close look at yours and then an earlier one...you will see what I a talking about. I learned the expensive way.....bought a left side and it would not fit on the left side....so had to buy a right side.
Good luck.
To pop up lights
