U-joint sizes?
Old Jul 16, 2012 | 12:11 AM
Bugman Jeff's Avatar
Bugman Jeff
Default U-joint sizes?
I searched, and either didn't see what I want, or found conflicting info. I need to replace all 6 u-joints on my '73 L48 manual trans car. I can't seem to find solid information on what size joints are required. Can someone tell me definitively:
What size are the half shaft joints?
What size are the driveshaft joints?
Are the driveshaft joints the same front and rear?
Thanks for the help.
Old Jul 16, 2012 | 12:35 AM
northern77's Avatar
northern77
Got this from a Tracdogg2 post
Drive shafts
All corvettes with 350 trans use 1330 u-joint.
All corvettes with 400 use 1330 u-joint.
All corvettes 71 -79 regardless of trans use 1330 u-joint.
All corvettes with manual trans 70 & older use 1310 u-joint.
Old Jul 16, 2012 | 05:23 AM
tracdogg2's Avatar
tracdogg2
Driveshaft 1330
Halfshafts 350
Old Jul 16, 2012 | 10:06 PM
Bugman Jeff
Thanks for the info.
I assume the "350" is supposed to be "1350"?
Old Jul 17, 2012 | 12:32 PM
tracdogg2's Avatar
tracdogg2
yes 1350 sorry about that
To U-joint sizes?
