1979 350 th transmission
Old Jul 18, 2012 | 10:37 PM
gpvett79's Avatar
gpvett79
Default 1979 350 th transmission
What holds the driven gear in place for the speedometer inside the trans my gear keeps sliding foward thanks
Old Jul 18, 2012 | 11:48 PM
DRIVESHAFT's Avatar
DRIVESHAFT
If your asking about the gear inside of the transmission, on the output shaft, its held by a metal clip that goes between the gear & shaft.
Old Jul 19, 2012 | 12:02 AM
gpvett79's Avatar
gpvett79
thank you for the replay where would i be able to buy this clip
Old Jul 19, 2012 | 12:22 AM
DRIVESHAFT's Avatar
DRIVESHAFT
Here is one option. http://www.transmissioncenter.org/GM...eter_Gears.htm
The TH350 stuff is about 2/3 of the way down the page.
Old Jul 19, 2012 | 07:22 AM
gpvett79's Avatar
gpvett79
Thanks for your help is there a diagram and instruction on putting it on the shaft
Old Jul 19, 2012 | 04:48 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Here is a video for you
They are working with a 700R4, but the gear retention is the same.
If you want to skip some of the beginning, go to about 3:30 in the video.
Old Jul 19, 2012 | 05:55 PM
gpvett79's Avatar
gpvett79
Thank you very much I believe I am ready to take on the job thanks
To 1979 350 th transmission
