MC testing
Old Jul 21, 2012 | 10:58 AM
lonzoo's Avatar
lonzoo
Default MC testing
Anyone know when testing a master cylinder by removing the lines and plugging the MC do you start the motor before you test the pedal movement??
thanks, Lonzoo
Old Jul 21, 2012 | 11:31 AM
Learning_Curve's Avatar
Learning_Curve
Should be able to do it either way. But plugging the master isn't needed. The brakes are a sealed system. If you don't have any leaks and the pedal continues to drop with when pressed, then you need a new master.
