New oil pan
Old Jul 21, 2012 | 12:04 PM
Steve Ference's Avatar
Steve Ference
Default New oil pan
Bought a new oil pan for my 434 sb, milodon #30908.
This pan is made for stroker small blocks and has a built in windage tray.
Perfect.
However, just discovered the the windage tray is held in place by dzuz type fasteners. Yikes. Big heavy crank and rods spinning at 7k plus close to 4 flimsy fasteners.
Has anyone used this pan and had good/bad results.
It must be standard fixing of the tray across the entire milodon range, but it looks a little weak to me,or am i being over cautious.
Thanks,
Steve.
Old Jul 21, 2012 | 01:27 PM
C3 Stroker's Avatar
C3 Stroker
Perfect.
Thanks,
Steve.
I have that same pan, and so far after a few years of 7k shifts, no problems at all.
Old Jul 21, 2012 | 02:08 PM
Steve Ference
Old Jul 21, 2012 | 03:13 PM
7t9l82's Avatar
7t9l82
moroso isn't some Chinese designed garbage I'd not give it a second thought. dzus fasteners hold panels on military aircraft so i don't see an issue on that point either.
Old Jul 21, 2012 | 05:42 PM
Steve Ference
Do you mean milodon,
Old Jul 21, 2012 | 06:06 PM
PeteZO6's Avatar
PeteZO6
Consider that many access doors and panels on military aircraft use dzuz fasteners to hold them closed or on.
Pete
Old Jul 21, 2012 | 06:59 PM
Steve Ference
Point made guys, i guess milodon do know their stuff.
Thanks,
Steve.
To New oil pan
