Big Block Water Pump rebuilding
Old Jul 22, 2012 | 12:18 AM
Bob3700's Avatar
Bob3700
Default Big Block Water Pump rebuilding
Any one know who could supply a rebuild kit or rebuild service for a short, aluminum GM water pump for a 427?
Casting number 3975928.
Don't want to replace the pump with an aftermarket unit, just re-bearing and re-seal this one.
Bob
Old Jul 22, 2012 | 02:09 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Your into a by gone era of rebuilding a water pump. But its not a lot of Rocket Sience once You get it apart just look at the Bearing and Seal Numbers and go to Your Local Bearing House. Shouldn't be a problem. I have a simaler Pump and plan on doing the same thing.
Old Jul 22, 2012 | 02:07 PM
Bob3700's Avatar
Bob3700
I figured that I could go the bearing/seal house route but thought that perhaps some of the kits that are out there for the iron pumps would work on this original GM unit.
Being a GM unit, that is the reason I want to rebuild as I want to keep it on my engine.
Bob
Old Jul 22, 2012 | 04:34 PM
Solid LT1's Avatar
Solid LT1
Howard Stewart can do them, no longer associated with the company that bears his name, I think a google search will find him for you.
Old Jul 22, 2012 | 07:09 PM
70BBvert's Avatar
70BBvert
Here's one place that I know of on Long Island. I'm sure there are more.
Jim
http://arthurgouldrebuilders.com/
To Big Block Water Pump rebuilding
