Replacing TH400 rear seal
Old Jul 24, 2012 | 02:39 PM
Roco71's Avatar
Roco71
Default Replacing TH400 rear seal
My car is a 1971 with a TH400 I am going to replace my U-Joints in the next week or so "while I am at it" I thought I would go ahead and replace the transmission rear seal as it has been leaking some. The question is can this been done without removing the cross-member and lowering the trans tail? Is it much of a job?
Thanks, Scott
Old Jul 24, 2012 | 03:10 PM
TimAT's Avatar
TimAT
Take a sharp chisel and collapse the old seal on one side, then it can be popped out. To install, pack the cavity on the back of the seal with grease- that keeps the garter spring from coming off when you drive the seal back in-- I run a thin bead of locktite around the OD- not needed is the seal has a bead os sealant around it already- then find a big socket that fits around the lip of the seal. 3 or 4 good shots with a large mallet and it's done.
Old Jul 24, 2012 | 03:34 PM
Roco71's Avatar
Roco71
Thanks, that's sort of how I visualized it just wanted to make sure there was enough room.
To Replacing TH400 rear seal
