Angle plug heads? Good or bad?
Old Jul 25, 2012 | 04:34 PM
superdave269's Avatar
superdave269
Default Angle plug heads? Good or bad?
I found a set of small block heads. The seller said they are the angle plug heads. He also said angle plug heads are not to popular. Why? My question is can I use stock exhaust manifold with angle plug heads? I was thinking about trying to use them on my 79 corvette(350, auto trans). Would I need to use headers or a different exhaust manifold? Would hate to buy them just to find out they don't really work for me. The car has a good(not rotted out) exhaust system so I don't want to change it out at this time.
Old Jul 25, 2012 | 05:05 PM
MelWff's Avatar
MelWff
read this article, if you have changed the pistons to high dome yes there is an improvement, if not no. What head part# are you considering? I use the early version referred to in the article, got them about 1974, with a domed piston.
http://www.carcraft.com/techarticles...s/viewall.html
Old Jul 25, 2012 | 05:14 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
No noticeable benefit, at first they tried to pawn them off as making more power, you don't here that anymore. Most of the time they angle the plug right into a header pipe, sometimes they angle it away so you can get at a plug, it's a crap shoot.
Not only are the angles different from different manufactures horizontally the can also and them up or down ( vertically ) too. And they never tell you what header to use. The header companies sometimes say "Will not work with angle plug heads" and their headers hit other things.
So like I said it's a crap shoot. Straight plug head might put the plug end into a pipe too so I don't think I need to say "crap shoot" again or not
As for being not so popular, I am not sure about that, there are millions of angle plug heads out there in cars
Old Jul 25, 2012 | 05:19 PM
Shark Racer's Avatar
Shark Racer
MotorHead has reminded me, every time I do spark plugs in the 78 I wish I had an LS motor.
Old Jul 25, 2012 | 05:25 PM
superdave269
I was looking at a set of Procomp aluminum 64 cc heads. I liked the price but that also worried me. Cheap usually means junk when it comes to car parts. I figured they would be better than the 76 cc 882 heads that are on the car now(125,000miles) My hopes were I could just bolt them on. A little worried about the hit or miss with the exhaust.
Old Jul 25, 2012 | 05:28 PM
MotorHead's Avatar
MotorHead
Looks like someone has an LS motor in their Avitar !
Shark Racer
Skip the procomps.
Old Jul 25, 2012 | 05:29 PM
MotorHead's Avatar
MotorHead
Grasshopper, find where in China the heads are made and ask them
Old Jul 25, 2012 | 05:31 PM
Shark Racer
Old car, just can't be bothered to change the avatar (haven't had the car since 2006, )
I've kicked around the idea of putting an LS in the '78 but the car is more about being a classic car and not perfect. There are little things (new radio, TKO) that make it better, but it still growls and idles like an old car.
I have 2 LS vehicles otherwise, and I like them both but it would just feel wrong for me to pop the hood and see something other than my half-assed L-82 clone with AFR heads under the hood.
Old Jul 25, 2012 | 05:46 PM
superdave269
Skip the procomps.
Are these junk? Are they made in China? Has anyone tried these?
Old Jul 25, 2012 | 05:51 PM
MotorHead's Avatar
MotorHead
Nothing beats the shake rattle and roll of a C3, just can't be copied, and oil under the motor in your garage no matter what you do
Old Jul 25, 2012 | 05:53 PM
MotorHead's Avatar
MotorHead
This has been beaten to death, try the search function and then look for heads made in the USA there are many at probably not too much more or cheaper than what you are looking at. Bottom line don't buy them
Old Jul 25, 2012 | 06:05 PM
Shark Racer
Summary: lots of bad machining that will need lots of correcting from a skilled machinist. By the time you're done you may as well have gotten the good stuff.
IMO if you have a long range goal with a motor, unless you've got a real bad jonesing, it's better to just go for it rather than nickel and dime yourself along the way...
Old Jul 25, 2012 | 06:06 PM
superdave269
Thanks, this is why I ask question here before I waste my time and money..
Looks like you guys saved me $350 Plus a lot of grief
Old Jul 25, 2012 | 10:59 PM
MotorHead's Avatar
MotorHead
$125 a head should tell you that, I paid more that for one set (2) of intake and exhaust shaft rockers Save up and by some good heads and don't be afraid post what you plan to do before you do we can still save you some money headache
Old Jul 25, 2012 | 11:20 PM
superdave269
I kinda knew it was to good to be true, that's why I asked about them. I still can't get over how nice everyone is here. Thanks again.
Old Jul 25, 2012 | 11:29 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
We are only nice sometimes.
Don't ask what kind of oil to use or if your excessive rear end side yoke play is a cause for concern. All hell will break loose.
BTW Procomp heads are junk. not even good boat anchors, too light.
Old Jul 26, 2012 | 07:58 AM
oldalaskaman's Avatar
oldalaskaman
best answer
Old Jul 26, 2012 | 08:56 AM
sajclayton's Avatar
sajclayton
8th Gear
I have a 350 motor in a 74 corvette that has Edelbrock 185cc Aluminum angle plug heads. Motor makes about 425 HP. I am running Hooker sidemount headers and pipes. I don't have any problem with the plugs or plug wires hitting the headers. I only have trouble tightening the # 2 plug but it is not that bad
To Angle plug heads? Good or bad?
