Best Set of Long-Tube Headers for a 350?
I'm looking for a good, hassle-free, best fitting (no modifications with a ball-peen hammer to make it fit), best looking (even after a while), ceramic coated, long tube headers. I've "searched" the forum but was unable to find what I was looking for. Any suggestions? My birthday is this weekend and my wife said "Go for it!" (Great Wife!!!).
By the way...how much better will the engine run after I get the headers installed? Horsepower? Torque?
My car had a set of Hedman 68300 headers on it when I got it. One is easier to get in from top and one is easier from the bottom. They have not been dented or dimpled.
I sent them to a place www.cradin.com they do aerospace coatings and put a 2 or 3 thousand degree black coating on the outside of them. All I know is they stay black and the finish has not changed.
As far as performance, Heads, cam and headers are the holy trinity for a sbc. My stock L48 put 190 rwhp with headers and an edelbrock performer intake with hei. You will like it but you have to be prepared for heat issues.
My next big upgrade will be a 2.5 system with straight through mufflers.
I went with hooker comp ceramic coated. With stock heads, edelbrock rpms & afr 195 straight plug, no modifications. You'll notice a difference. The difference is compounded with further engine modifications.
http://www.stans-headers.com/tri_y.htm
I hope ti install a set of the 109Y headers someday..........
Keep the shiny side up!
Scott
Scott
No typo, stock heads first, upgraded to edelbrocks on the stock bottom end, built a dart 400 when the l48 became tired, it would have been a shame not to run better heads. Correct me if I'm wrong but aren't tri y's long tubes that break two into two and then those merge at the collector, as were long tubes merge 4 into one at the collector.
Ah, I get it now that you explain it. As far as tri-y headers, not sure what you mean by "break two into two", they go 4 into 2 into 1. All you have to do is take a look at a pair of 'em. There are 3 spots where 2 pipes merge into one pipe, like the letter "Y", hence the term "Tri-Y".
Scott
Scott
Scott
still to the point they are still long tubes.
