Cam and lifter types...3 types?? Solid, Roller, Hydraulic?
Old May 28, 2002 | 08:28 PM
Maurice's Avatar
Maurice
Default Cam and lifter types...3 types?? Solid, Roller, Hydraulic?
Is this correct? Or is the roller type a subset of one of the others? Are there other types?
Thanks.
Old May 28, 2002 | 08:36 PM
70 LS1's Avatar
70 LS1
Default Re: Cam and lifter types...3 types?? Solid, Roller, Hydraulic? (Maurice)
A roller cam can either be solid or hydraulic. It just refers to the roller bearing that rides on the camshaft lobes. Usually, you can have quicker ramp rates with rollers which essentially has the valve open longer for the same duration numbers. The valve will reach full open sooner and start to shut later. This makes the valves more efficient. Since you are opening the valves quicker, there is more stress on the valve train.
There is also a lot less lobe wear since you don't have the bottom of the lifters sliding across the lobes.
Old May 28, 2002 | 08:38 PM
Maurice's Avatar
Maurice
Default Re: Cam and lifter types...3 types?? Solid, Roller, Hydraulic? (70 LS1)
So you always use solid lifters with a solid cam, roller with roller, and hydraulic with hydraulic? But roller can be solid roller or hydraulic roller?
Old May 28, 2002 | 08:40 PM
70 LS1's Avatar
70 LS1
yup, you got it.
Old May 28, 2002 | 08:44 PM
Maurice's Avatar
Maurice
[Elvis voice] Thank you, Thank you very much [/Elvis voice]
Old May 28, 2002 | 08:46 PM
Maurice's Avatar
Maurice
What type would this be?
http://dab7.cranecams.com/SpecCard/D...1=Display+Card
Old May 28, 2002 | 10:02 PM
Gordonm's Avatar
Gordonm
That looks to be a solid roller. A solid cam will always give you valve lash in thousandths of an inch. A hyd will be 1/2 or 1 turn past zero lash depending on the cam.
To Cam and lifter types...3 types?? Solid, Roller, Hydraulic?
