rims and tire clearance issue...HELP
The standard wheel on all 69-82 Corvettes, was the 15x8 rally. From 76 to 82, the 15x8 slotted aluminum wheel was optional. The optional tire on all 78-82's, was a P255/60R15, which is a bigger tire, than the one your trying to use.
Chevrolet would trim the forward edge of the inner wheel opening lip, on 78-79's that were factory equipped with 255/60's. This was to prevent the tire from making contact, with that area of the wheel opening. This was the only change Chevrolet made, when the 255/60's were used. I have heard that some people have occasionally experienced a tire rub on the frame with the 60's, but only at a combination of full lock steering and under extreme suspension load conditions. This doesn't sound like what your experiencing.
The wheel offset isn't a problem with the Corvette front suspension anyway. The offset problem occurs with the rear suspension, where the wrong offset will cause the rim/tire to either contact the trailing arm, the parking brake cable bracket and/or the ends of the rear spring.
Why do you have spacers in the front suspension? Did you try mounting the wheels without the spacers?
I would dump the spacers either way! Chevrolet didn't use them, and I wouldn't think you should need to either.
...all is well and thanks for all the info. I saw where you could get corvette with the 255 tires and I was like WTH these should fit also...
