Body bolts
Old Jul 30, 2012 | 08:08 PM
wantingc2's Avatar
wantingc2
6th Gear
Default Body bolts
Tackling a 1982 body off restomod, really having trouble with the body bolts. Any help or suggestions would be appreciated.
Old Jul 30, 2012 | 08:58 PM
terry82's Avatar
terry82
http://www.youtube.com/watch?v=VEMJc...&feature=g-upl i would try a dremal with a cutoff wheel.
Old Jul 30, 2012 | 09:51 PM
dgood's Avatar
dgood
sawzall them off.
Old Jul 30, 2012 | 10:20 PM
spdrcr29's Avatar
spdrcr29
Bust out the air grinder and grind the heads off all of the stubborn/rusted/rotted bolts. Then you should be able to lift the body...
Old Jul 31, 2012 | 02:23 AM
mapman's Avatar
mapman
Don't forget the (1) body mount bolt that attaches the center front of the car to the bumper brace (on 1980-1982) cars.
Soak the bolts with Kroil or PB Blaster over several days to try to break the rust. On my car the #3 passenger side nut/bolt froze up and spun in the cage welded to the frame.
Not much room to work, and I ended up wrapping a hacksaw blade with duct tape in order to get clearance to sever the bolt. (Zen or the old B&W prison movies should get you in the correct frame of mind!)
Old Jul 31, 2012 | 07:18 AM
MIKE80's Avatar
MIKE80
Use a Sawsall. I used these blades and they worked awesome! I actually shortened one of the blades so I could get in and cut the trailing arm bolts, which made that job much easier!
http://www.northerntool.com/shop/too...3524_200213524
Old Jul 31, 2012 | 08:36 AM
stpman's Avatar
stpman
This is what I did
To Body bolts
