poly bushing and road noise
Old May 29, 2002 | 02:52 AM
LATNC3's Avatar
LATNC3
Default poly bushing and road noise
how much road noise should i be experiencing? i have replaced all the rearend bushings with poly ones and rebuilt the rearend. the noise is almost a grinding sound...........could you guys help me out?
Rod :cool:
Old May 29, 2002 | 02:56 AM
R. Bruno's Avatar
R. Bruno
Default Re: poly bushing and road noise (Rod Rodriguez)
Did you refill the rear with oil AND additive?
Old May 29, 2002 | 03:00 AM
LATNC3's Avatar
LATNC3
Default Re: poly bushing and road noise (R. Bruno)
yes......might need a bit but i did put the additive and the 80-90 weight!!!
Rod
Old May 29, 2002 | 03:13 AM
Chris O''s Avatar
Chris O'
Rear bearings? Uni joints? I have poly and no noise.
:cheers:
Old May 29, 2002 | 03:47 AM
C3 Shark Tank's Avatar
C3 Shark Tank
Did you have a complete rear diff rebuild? I was told to either drive a tight figure 8 about 10 times, or circles in each direction to break everything in, something to do with the clutches and helping the posi lube get mixed in. You shouldn't have a grinding noise, I have poly bushings and when my diff was rebuilt including new gears there was no noise at all, at least none other than the usual road noises.
Old May 30, 2002 | 04:35 PM
LATNC3's Avatar
LATNC3
Default Re: poly bushing and road noise (C3 Shark Tank)
i don't know guys, i hear grinding noise........i went to get my rearend aligned and the guy told me that it could very well be bearings!! it seems to get a bit louder when i slow do idle speed!!!! could this be a rebuilt problem?
Rod :cool:
Old May 30, 2002 | 05:25 PM
Fevre's Avatar
Fevre
Can you tell where it is coming from? If not put the rear up on jack stands and put it in gear. If it is bearings, they probably won't grind since not much weight on em in the air, if rear end you should be able to hear it but it may be lighter too because of less stress. I hate chasing down funny noises so I feel for ya bro.
Old May 30, 2002 | 05:29 PM
LATNC3's Avatar
LATNC3
Default Re: poly bushing and road noise (Fevre)
never thought about putting it on jackstands...but i will. i'll let you know!!!
Rod :cool:
Old May 30, 2002 | 05:34 PM
Fevre's Avatar
Fevre
Note I said jack stands not jack! ;) But you knew that already. :lol:
Old May 30, 2002 | 05:53 PM
Larry B.'s Avatar
Larry B.
No... No... No... Don't do that. The wheels hanging will put the half shaft U joints almost in a bind... Not good! You can put the car on jackstands and then support the wheels at the spring mount to get the half shafts fairly straight.
Old May 30, 2002 | 06:41 PM
Fevre's Avatar
Fevre
Default Re: poly bushing and road noise (silvervetteman)
That's odd, I did it when I was chasing a speedo error and had no problems. I certainly would not red line it but having the car in gear at idle caused me no problems. I also rotate the tires as I put the lug nuts on at that doesn't hurt it. I can't see the car engineered so that if the butt end gets a little airborn it ruins anything. Of course supporting the spring would not hurt the car either so I guess it is your call Rod.
Old May 30, 2002 | 09:22 PM
Larry B.'s Avatar
Larry B.
Yes you can do that but... It's just that the U joints are at their extreme. This would only be a momentary thing while drving. That is why constant velocity joints are a better design. Some aftermarket U joints (especially those with grease zerks) can actually bind enough to break. There is even a caution about this practice in some manuals. At best it is very hard on the U joints. :cheers:
Old May 30, 2002 | 10:25 PM
paso's Avatar
paso
Stop by Rod I'll give you a opinion. :D
Old May 30, 2002 | 10:37 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: poly bushing and road noise (paso)
Does it make more noise turning left VS right?
A wheel bearing should be louder with more load...
Old May 31, 2002 | 08:03 AM
Fevre's Avatar
Fevre
Good point. Maybe he can rotate it by hand first to see if it makes noise or causes binding then maybe try running it in gear at idle. Better safe then sorry.
To poly bushing and road noise
