I was advised against headers & bigger pipes
Spoke with a few vette guys with many years of vette racing experience who told me not to waste my money unless I plan on racing the car (which I do not see myself taking it to the track). They said headers and 2.5" pipes are overkill for a stock 350 and the motor wont breath right. They said that yes, I may feel a little more HP but not worth the work/money. The advice was to upgrade exhaust to the next size up from stock OR leave it alone and just throw on new mufflers for better sound.
Are they completely off or should I trust their experience?
BTW....what is the stock exhaust size on a small block?
If you are not making any major modifications to your motor I would do the exhaust headers and tie into what you have. Little cheaper but probably best bang for the buck for now. After that if you add any heavy engine mods then get larger pipes and mufflers later.
The other upgrades are mostly in the suspension/steering department...none on the motor... this is why I am considering putting off exhaust work until it can REALLY show some improvement.
the best part .... its your hot rod .... you get to choose what you do to it ....
ENJOY !!!!
Keep the shiny side up!
Scott
This year I rebuilt the tranny, replaced the clutch, redid the rear main and put in a new exhaust.
My L-48 engine is stock and my long tube headers and dual exhaust have helped performance. I did not tweak the carb. Also, I needed a new exhaust system. The old one was rusty and leaking. I did not want to go halfway or have to touch it again so I went with stainless headers and ceramic coated them. I also got the Magnaflow 16842 system which is 2.5" with an x-pipe. I love it.
I heard the same comments about free flowing exhaust hurting performance or not being able to tell a difference. My experience is the complete opposite.
Scott
78 L-82 4 Speed totally stock internals (cam, heads, intake, pistons etc), 65,000 miles (time of dyno last year) with the only changes from the OEM factory components:
1. Holley 650 CFM spreadbore Qjet replacement-lightest vacuum secondary spring Holley sells versus the one that came in the carb.
2.Comp Cams Roller tipped 1.5 rockers (same ratio as stock, not true rollers).
3. McJacks Shorty headers, not block hugger headers.
4. 2.5 inch true duals with Monza Turbo mufflers-no cats.
78 L-82 rated from the factory at 220 Net HP
4 Dyno pulls in Oct 2011 with Forum member, Karol, witnessing as well.
Best pull was 233 RWHP which is about 290 Net HP using a 20% correction factor for drivetrain loss or about 330 Gross HP (pretty even with the 330 Gross HP LT-1.
You decide if it is worth doing the exhaust?
Scott (scottyp99) has some excellent advise - take heed!!
Scott
L46 is 11 to 1 comp, big hydraulic cam, 2.02 valves, screw in studs, Forged crank, pink rods, 1 HP per CI with a low rise intake and stock manifolds. This is not a typical "stock" engine but a hydraulic cam version of an LT1. Headers and a low restriction 2 1/2" exhaust is the best bang for your buck improvement you can make on this engine. A good flowing intake is right up there. Performance distributior recurve is a must. You should see close to 400 actual FWHP with these two upgrades.
This is a long read but Super Chevy thinks you can lose a bit of torque if the pipes are too big. http://www.superchevy.com/technical/...h/viewall.html perhaps bs.
I spoke with a Magnaflow tech and he said that they crush bend their mufflers to reduce sound. That is why I am going to try the ones in this video. http://www.youtube.com/watch?v=wxPIt-eoT3w
My car rear wheel dyno'd with 270 hp through a TH400. I have long tube headers and plan on a 2.5 in crush bent system with the Jones mufflers.
The engine should make more power everywhere, but, if I understand how long tube headers work, it will gain more top end power than it does low end power. That might be what hal1phx is trying to express. On the other hand, maybe not.
Scott
My stock L48 was night and day improved when I went from exhaust manifolds to headers. It was power you could feel and it proved it.
0-60 times (against an accelerometer) went from 7.1 seconds down to ~6.5. In other words, with headers my stock automatic 78 L-48 was hitting 60 faster than a 4-speed L-82.
These effects will be even greater on a high performance motor, as mentioned above.
$300 for about 30 hp? It doesn't get better than that. The next big bump for me cost close to $3000.
