74 Washer Pump
Old May 29, 2002 | 09:55 AM
74L82AirRoadster's Avatar
74L82AirRoadster
Default 74 Washer Pump
Good morning everyone!!
I'm looking for a 1974 washer pump, the whole unit including the backing plate everything is attached to. ZIP sells units for 68-73 and 75-82 but no 74 for about $51.00. Anybody have a source of any ideas on what's different? I tried the local Advanced Auto and they just have rebuild kits. Any info would be appreciated!!
Old May 29, 2002 | 05:16 PM
Larry B.'s Avatar
Larry B.
Default Re: 74 Washer Pump (74L82AirRoadster)
74's are not different. I would see what a 73 and a 75 unit looks like and compare. Most places sell rebuild kits for them also. I just did my 69 which is a one year only pump but a later one would fit. I used parts out of a new one to rebuild my original one. It is not aseassy as it appears at first glance. ;) :lol:
Old May 29, 2002 | 09:16 PM
chuck d's Avatar
chuck d
Hi:
Find a AC Delco jobber, they sell a complete washer pump with the small parts that go with the drive portion of the windshield wiper motor assembly. I bought one a couple of years ago for about thirty dollars, the only problem is the pump assembly is black. The pump is still available from the general I believe but the cost is much more (it's black also).
I ended up rebuilding my pump with a kit I bought from Pep Boys, it worked out good and it retained the white color.
So it looks like you have a choice, rebuld yours or buy a black pump assembly.
Good luck Chuck D
[Modified by chuck d, 7:19 PM 5/29/2002]
Old May 29, 2002 | 10:11 PM
SnoDrgn's Avatar
SnoDrgn
From: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Default Re: 74 Washer Pump (chuck d)
I bought a rebuild kit for mine too. Everything worked out good and went together smoothly. :yesnod:
To 74 Washer Pump
