body mount modification?
Old Aug 1, 2012 | 06:08 PM
gcusmano74's Avatar
gcusmano74
Default body mount modification?
So, to review, the C3 has 8 rubber bushed body to frame mounts, and two solid (metal to metal) mounts under the radiator.
Why aren't those two forward mounts set in rubber as well?
What if I rubber bushed those mounts under the radiator support by using, say, two shock absorber bushings and a longer bolt? The unthreaded shank of the bolt would be sized to span the extra depth of the two shock absorber bushings. A 2 1/2" long bolt would have an unthreaded shank of an inch or so, and work out nicely. That modification should improve the NVH a bit, I think.
What's the downside to something like that?
Old Aug 1, 2012 | 10:47 PM
SIXFOOTER's Avatar
SIXFOOTER
Where are you going to put this bushing and what it going to fix?
Old Aug 2, 2012 | 09:40 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What model year? What are you calling "solid metal mounts"? What is NVH?
Old Aug 2, 2012 | 09:55 AM
69 Chevy's Avatar
69 Chevy
Noise, vibration, and harshness???
Old Aug 2, 2012 | 10:08 AM
gcusmano74's Avatar
gcusmano74
The body lands on the frame in 10 places on a C3. On my '74, eight of the places are rubber bushed; the two under the radiator support are metal to metal. So any vibrations in the frame are transmitted directly to the radiator support, and through that, the rest of the body. I just thought it might improve the Noise, Vibration and Harshness damping if I rubber bushed those last two places.
I'm going to do it and report.
Old Aug 2, 2012 | 12:10 PM
mapman's Avatar
mapman
Originally Posted by gcusmano74
So, to review, the C3 has 8 rubber bushed body to frame mounts, ...
The 1980-1982 cars have one additional rubber bushed body mount at the front center of the car between the front bumper support and the body.
To body mount modification?
