Runout?
Old May 29, 2002 | 10:42 AM
DVG73's Avatar
DVG73
Default Runout?
I have an idea what runout is and know how to check for it and I even have the dial calipers to check on it, but I am unclear as to what it really means. Anyone help this dummy out? :smash:
Old May 29, 2002 | 11:42 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: Runout? (DVG73)
This may get you started..........
http://www.dippy.org/svcman/sm05i.html#CHECKING
Old May 29, 2002 | 12:04 PM
Barry's70LT1's Avatar
Barry's70LT1
"What is rotor runout".
It's when the wheel/rotor turns and the rotor, for a lack of a better word, wobbles. In other words "bent", or not running "true".
CAUSE, warped rotor, or bent hub.
RESULT, the wobble in the rotor hits the caliper pistons and pulses them in/out and pumps air into the brake system.
Result, no/poor brakes, pedal to the floor.
ANOTHER CAUSE, is when there is too much "play" in the wheel bearings and causes the same wobble and the same problem.
Use a dial guage to check each rotor. With the dial guage at right angles to the rotor, near the outside edge, rotate the rotor and observe the total amount of "wobble", or runout. More than a few thou will cause brake problems.
THE CURE, If it's only the rotor, replace it. However it could be the hub under the rotor that is the problem.
If so, shim the hub to bring the rotor to within a .001 - .002 runout.
The best cure if it's the spindle flange (hub), is to heve a machine shop true up the flange.
Don't forget to check the wheel bearings for excessive play.
Hope this helps.
Barry
Old May 29, 2002 | 12:30 PM
GTR1999's Avatar
GTR1999
Default Re: Runout? (Barry's70LT1)
Barry's has it down pretty good. One thing on the spindle flange runout,I just installed new Tom's spindles and the runout on these is .002" which translates to .005-.006" at the outer edge of the rotor. I had to shim them to bring them in to .001-.002" runout. I really wasn't happy with this but didn't want to press off new bearings and take a big chance of wrecking them.
Gary
Old May 29, 2002 | 12:46 PM
DVG73's Avatar
DVG73
Thanks for the info guys. I thought it meant wobble but was not sure, this clears things up for me.
Old May 29, 2002 | 06:52 PM
Turbo-Jet's Avatar
Turbo-Jet
a good idea for shimming:
order a few sets of 1/2" Arbor Shims, .001 or .002 thick, from Reid Tool in MI
shims are precison ground hardened steel, just put them over lug stud between rotor and spindle flange
Old May 29, 2002 | 06:58 PM
mrvette's Avatar
mrvette
IF you remove the spring from behind the pistons, and use O ring pistions/seals you will have no 'runout' problems...UNLESS the runout is .1 inch or so...
about ten times the 'allowable' of a stock spec'd system...
GENE
Old May 29, 2002 | 09:11 PM
Barry's70LT1
Default Re: Runout? (Turbo-Jet)
I used an old set of feeler guages as shims. Simply cut off the one that is the correct thickness. Feeler guages have the thickness labeled. You can always find the exact one to do the job.
I glued it to the spindle flange so it would stay in the correct location. (Weatherstrip glue)
Old May 29, 2002 | 10:08 PM
GTR1999's Avatar
GTR1999
Hey Barry,
I used sheet shim stock and knock punch set. I punched a 7/16" hole and slid the .002" shim over the stud. You can get this stuff at MSC or any industrial supplier.
Gary
Old May 30, 2002 | 01:09 AM
Stevo81's Avatar
Stevo81
My friend Bubba had a fine Vette but his wife took it and runout on him.
Does that help?
Old May 30, 2002 | 11:42 AM
FeedVaal's Avatar
FeedVaal
Default Re: Runout? (Stevo)
I think that's R U N N O F T.
To Runout?
