Tail Lights Dim
Old May 29, 2002 | 06:10 PM
Bond007's Avatar
Bond007
Default Tail Lights Dim
Hello fellow VETTEHEADS, have a little problem with the brightness of my tail lights. I'am assuming that I may have a grounding problem? Can anyone shed some light(pardon the pun) on this for me? When the brakes are applied the lights are bright as usual, but when the lights are on ,the tail lights are about 1/2 the illumination. As always, thank you in advance for any information you can provide.
Peter :flag
Old May 29, 2002 | 06:13 PM
82dukman's Avatar
82dukman
Default Re: Tail Lights Dim (Bond007)
Start with the obvious, change the bulbs. There might be dirt all over them
Old May 29, 2002 | 07:51 PM
Pete79L82's Avatar
Pete79L82
The ground for the tail lights is at the end of the left frame rail. I would clean it real good to see if that is your problem.
Old May 30, 2002 | 07:34 AM
Gary79's Avatar
Gary79
Default Re: Tail Lights Dim (Pete79L82)
i cleaned the ground and the area grounding to,smeared a little dielectric grease and the illumination almost doubled. new bulbs help also.BTW also put new halogen headlights in the front, 20 yr old halogens seems to lose their stuff over time.
To Tail Lights Dim
