A/C problems on a 74 Vette
Old Aug 8, 2012 | 03:24 PM
Fixit01's Avatar
Fixit01
7th Gear
Default A/C problems on a 74 Vette
Does anyone know what kind of temp. that I should be showing on my a/c thermometer in a 74 Vette that has been competely changed over to 134a? I am only getting a reading of 58-60 degrees. If it's supposed to be lower, will adjusting the vacuum switch in the console help? Also, how do I post pictures of my cars?
Old Aug 8, 2012 | 04:35 PM
MelWff's Avatar
MelWff
what was the outside temperature when you took the reading and was that at idle or while moving at speed? Try this for posting pictures
http://forums.corvetteforum.com/faq....l&titlesonly=0
Old Aug 9, 2012 | 01:07 AM
tracdogg2's Avatar
tracdogg2
73-E76 vettes use the VIR (valves in reciever) system. They really don't like R134.
Mike
Old Aug 9, 2012 | 04:14 AM
Fixit01's Avatar
Fixit01
7th Gear
Outside temp was around 85 and I am aware of the VIR. I had it rebuilt but should have put an accumulator in.
Old Aug 9, 2012 | 10:50 AM
brrujo's Avatar
brrujo
Delta-Temp should be about 40 degrees. This is measured at the face of the evap (incoming air) and at the backside of the evap. (outgoing air). This need s to be checked at the evap as you will get a few degrees temp rise through the duct work. Any more than around a 10 degree change through the ducts would indicate a possible hot air bleed through. Make sure your temp cable is adjusted properly and the seal on the blend air door is good and tight.
I have a 73 with the VIR that has been converted to R134A and it seems to work as R12 did except at idle. To fix this I would need to switch to a more efficent condenser.
Old Aug 9, 2012 | 11:58 AM
Fixit01's Avatar
Fixit01
7th Gear
Thanks for the info. Going to check those tubes now.
Old Aug 9, 2012 | 01:18 PM
Fixit01's Avatar
Fixit01
7th Gear
Between 40 and 45 degrees. Got to be vacuum. I've been told that one can adjust the Vacuum switch in the console to help the situation. Any thoughts?
To A/C problems on a 74 Vette
