Radiator cap pressure
Old Aug 8, 2012 | 03:39 PM
BHRIG's Avatar
BHRIG
Default Radiator cap pressure
What is the proper radiator cap pressure for a 77 L48......no mods?
I have a 16 lb cap on, but the hoses are all hard as rocks with engine running.
180 degree stat with holes drilled......
there is a mixing of fluid from the radiator as the overflow tank does get hot.
engine runs at about 220 degrees with air conditioner running at highway speed(65-80).
Thanks for input in advance
Old Aug 8, 2012 | 03:51 PM
ED79's Avatar
ED79
I was thnking it is 15lb but I've been wrong before, have you flushed the system out yet? Ed
Old Aug 8, 2012 | 04:15 PM
BHRIG's Avatar
BHRIG
Radiator flushed.........
I'm concerned about excessive(?) pressure.
Should hoses be hard?
Old Aug 8, 2012 | 04:21 PM
Mike Ward's Avatar
Mike Ward
Yes, that's the whole point of a pressurized system.
Old Aug 8, 2012 | 04:24 PM
MelWff's Avatar
MelWff
thats the correct pressure cap also
Old Aug 8, 2012 | 04:27 PM
BHRIG's Avatar
BHRIG
Thanks, just making sure.......
I went over the whole system and replaced items as needed..
I never had a pressure build up before and never had an overheating
situation........
To Radiator cap pressure
