hi
I have delete the AC stuff, cut the plastic box in two and inside I find a Resistor.
I dont realy know what its the purpose of this piece, can I delete it too
I removed my ac from my 77 and remounted that resistor in another non ac heater box from a 69 . Works fine, dont really care about heat, but ya may need defrosters if you get caught in the rain.
Tanks for the help
I cut the plastic box in two due to reduce it and reuse without the ac stuff I still dont understand th resistor purpose technical, I can understand from the switch change voltage so the speed get diffenent butif you look at this piece withsprings etc inside the heter channel must have something to do with air temp?
