electrical problems
Old Aug 10, 2012 | 10:42 AM
hall's Avatar
hall
7th Gear
Default electrical problems
My 78 corvette has a short of somesort the courtesy lights will work for 3-4 hours then blow out the 20a fuse put a new one in and it blows out as fast as i push it in any ideas i think the antenna works off the same fuse could it be the antenna shorting (HELP)
Old Aug 11, 2012 | 09:05 AM
oldalaskaman's Avatar
oldalaskaman
you have a hot wire grounding out ....somewhere, does your radio antenna work at the same time and then quit also?
Old Aug 11, 2012 | 10:23 AM
hall's Avatar
hall
7th Gear
yes the antenna stops working any ideas where to look for problem i am new to corvettes
Old Aug 11, 2012 | 12:06 PM
oldalaskaman
there's two simple ways to start, remove the light bulb and see if it still blows the fuse, if it doesnt the issue is in that cir-cut, if it still blows put the bulb back in and disconnect the antenna wire, kinda a process of elimination. after that a multimeter is a good thing to have.
Old Aug 11, 2012 | 12:42 PM
mrvette's Avatar
mrvette
Unplug the antenna motor harness in back, it's not cutting power in the end stop going up/down, and so it sets there drawing current and finally popping the fuse....bet the motor is hot too.....
Old Aug 11, 2012 | 03:03 PM
hall's Avatar
hall
7th Gear
I think I've narrowed it down to the antenna just have to figure out how to get at the wire for the antenna not sure what keeps the wire hooked up and once my arm is up there I have no vision at all and only the one hand in there
Old Aug 14, 2012 | 06:21 PM
hall's Avatar
hall
7th Gear
does anyone know how to disconect the power antenna on a 1978 corvette is it at the radio or the antenna itself
Old Aug 14, 2012 | 07:50 PM
Andeep's Avatar
Andeep
To remove the power antenna there is a relay behind the rear centre console reinforcement. The 3 cables from the antenna (green, white and grey) run up into the body through a gromet behind the drivers side rear wheel. They then goto the relay at which point you should be able to disconnect them. Post relay has 2 cables (orange (hot) and yellow ( hot with ignition). If you have any more questions u can pm me. Hope this helps
Old Aug 15, 2012 | 08:33 AM
hall's Avatar
hall
7th Gear
is there a sight i can view a diagram or something so i can see it
Old Aug 15, 2012 | 11:09 AM
Andeep's Avatar
Andeep
Check this thread out there is an image of the power antenna relay which is under the armrest.
Http://forums.corvetteforum.com/c3-g...nna-wires.html
Old Aug 15, 2012 | 05:55 PM
hall's Avatar
hall
7th Gear
is t5here someplace i can find a diagram of wiring for the power antenna up to the radio and maybe i can unplug the power just to see if it solves the problem then i could correct it
To electrical problems
