Idler Arm part 2 - pics
Old Aug 10, 2012 | 09:02 PM
79vetter's Avatar
79vetter
Default Idler Arm part 2 - pics
Really frustrated with installing my same idler arm back onto the frame. I removed it from the steering arm to make things easier.
My problem now is that I can only put one bolt in (out of 2) at a time but then I can't put the 2nd one in. The flat of the idler arm won't line up with both bolt holes at the same time. This is because the top of the idler is hitting the frame before I can line up both holes at the same time.. This should be easy ...because this same idler arm was mounted before
You can see how far the top hole is missing when the bottom bolt is installed
Here is the idler arm hitting the frame:
Old Aug 10, 2012 | 10:19 PM
mds3013's Avatar
mds3013
You are trying to bolt it up with the tapered stud on the outside of the frame? It all lies between the frame rails. Point the tapered stud end toward the front of the car on the inside of the frame. mike...
Old Aug 10, 2012 | 11:13 PM
79vetter's Avatar
79vetter
thank you for the reply and picture - that helps.
Old Aug 12, 2012 | 09:37 AM
69 Chevy's Avatar
69 Chevy
To Idler Arm part 2 - pics
