stock fuel pump question???
Old Aug 11, 2012 | 09:12 AM
STL 71 C3's Avatar
STL 71 C3
Default stock fuel pump question???
Will stock fuel pump with return line support 450 hp 408ci engine with 750 holley dp? Would you upgrade to something else or try it?
Not drag car just street toy.
Old Aug 11, 2012 | 10:45 AM
BKbroiler's Avatar
BKbroiler
Supposedly a stock pump will handle 500 hp. I'm not close to 500 or even 450, but a stock pump, with return, works fine on my 383. I've run 12.40 at 107 with it.
Old Aug 11, 2012 | 11:32 AM
STL 71 C3's Avatar
STL 71 C3
thanks!
With that time I bet your close if not at 450hp...
I guess I will try it and maybe mount a fuel pressure gage to check it during WOT.
What about radiator? Any concerns there?
Old Aug 11, 2012 | 01:13 PM
texas jim's Avatar
texas jim
Depends what the carb you have calls for. You can check the fuel pressure w/ a gauge against what your carb info says it needs.
Old Aug 11, 2012 | 01:15 PM
BKbroiler's Avatar
BKbroiler
I'm using a stock type replacement radiator, but it is the 4 row L82 engine sized unit. I have ALL the seals around the shroud and the top of the radiator to hood gap in place. I'm using the stock clutch fan and a low flow Moroso aluminum pump. I have zero cooling problems, even when racing in summer conditions.
Old Aug 11, 2012 | 01:19 PM
STL 71 C3's Avatar
STL 71 C3
max is 0.569 BSFC lb/hph @ 6000 rpm
Do you know what the stock pump can provide?
Old Aug 11, 2012 | 01:21 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Originally Posted by stl 71 c3
will stock fuel pump with return line support 450 hp 408ci engine with 750 holley dp?
yes!
To stock fuel pump question???
