Can someone guesstimate or desktop dyno this combo for me? Putting together info on current and potential mods.
Thanks Gary.
350CI
4bolt mains
cast pistons-9:1
WP SR Torquers 67 cc 202/160
Performer intake
750 Q-Jet
1 5/8" headers into 2.5" chambered
Comp 270H or 268XE cam
CC 1,5 roller tip rockers
Stock point dist, 40k volt coil
may go into the 69 M-20 373
You should run the compression estimator and show the assumptions on
head gasket thickness/piston crown/quench area.
I would think that you will get more than 9:1 compression. Thus your
graphs would go up about 10-20 HP.
BTW, you have the cam with no advance - Comp Cams are built with 4 degress
advance. Should this be put in there? That will increase high end
power...
Adam,
Regardless of how you get there, 9:1 is 9:1. You may be right, he may be higher, but there's now way of knowing that without actually cc'ing everything.
If you would like to simulate a cam with a ground in advance, you would do it in the cam specs. For instance, a 110 LSA cam with 4 degrees ground in would have a 106 intake centerline. The "advance" window in the main screen is to simulate the installed position (as in, a timing set with advanced and retarded settings). Does that make sense? :D
Thanks Joe, I appreciate it.
Looks like a 350Hp-380ft combo not bad but how would I get to 400HP or over 400 ft/lbs? Again this in the designing stages.
Gary :cheers:
I was thinking that 9:1 may be understating the compression. As you mention
CC's is necessary and correct math. The calculator may be more accurate
and will give a good estimate to work towards.
As to getting 400 tq/hp, 10:1 or better compression helps,
ported heads (torquer is a good start) A Crane 274 gives a little
higher hp (at higher rpms) at a small exchange for tq.
if you have time - would be great if you could desktop dyno my new engine: A mule engine with the same setup was dynoed at 465 HP.
I wonder what the Dyno2000 would calculate for this engine:
Here are the components:
383 ci
9.8:1 compression (Hyperutectic Pistons)
steel crank
Custom Ground solid cam 248/238 degrees @.050 and .545/.525 lift
Dart Iron Eagle Heads with 64cc chambers and 215cc intake runners - ported and 2.05/1.60 valves
Performer RPM Intake
LUNATI Roller Rockers 1.5 Ratio
Holley 750 carb
Oliver,
When is the new motor due???
Sounds like a nice combo.
Are you going to the Tower Shops tomorrow nite?
Motor should arrive by tuesday or wednesday. It was shipped yesterday by truck!
:cheers:
Olivier
P.S. I will be at the Tower Shops tomorrow if the weather will be ok!
However - I won't stay too long because I will drive my Duntov to Clearwater for the weekend. I will also take the Duntov tomorrow to the Tower Shops!!!
Olivier, to simulate an engine with ported heads, you would need the actual flow numbers for those heads after the porting work. At that point, they are basically "one of a kind".
If not considering the porting - how many HP would the Dyno estimate?
