Can a pre-bent (unwelded) 10 point roll cage be assembled/installed in a lightened 1978 C3 without lifting the body off? Any guidance would be very much appreciated. I was thinking of an Art Morrison cage, and planning to get into the high 8 second range in the quarter with a 638ci Dart block, a performance TH400 and a Ford 9 inch with a spool.
I am almost finished installing a 10 point roll cage in my 1980 C3, did the install with the body on the frame but all the interior is out of the car. It is a fairly easy job, just takes time and a little head scratching at times. I used a Harbor Freight tubing notcher to fit the weld joints, it worked really nice and is only about $45. Also used mig welder, and a Harbor Freight hydraulic tubing bender to fine tune the bends for a better fit. At all the points where the tubing is welded to the frame, I simply cut a hole in the body and welded a 1/4" plate on the frame and then welded the tubing to the plate. My car is going to have a race car type aluminum dash, so it was a little easier to install in the dash area, in other words I will fabricate the dash to fit around the roll cage. It was not a bad project, but someone that has installed these could have done it 10 times faster than I did. Hope this helps, good luck. PS I purchased my roll cage kit from Jegs.
You are better off buying a full tube drag race roller frame for what ever motor and tranny combo made for any body style you want.
Once You have the car that far apart whats the big deal about lifting the body. I did my 4 point cage for my street car with full interior by lifting the body just enough to get in there and weld it, maybe 2" or so.
Raising the body a few inches is a great idea. I didn't know that was possible with a full interior. Are the body mounts the only items needing to be undone?
