TPI start, slow?
Old Aug 16, 2012 | 11:12 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Default TPI start, slow?
Perhaps I'm spoiled by newer cars, but I expected the car to start quicker once the TPI + HP EFI were installed.
Does this seem slower than normal?
http://www.youtube.com/watch?v=U7WdTZA5Y5c
Old Aug 16, 2012 | 11:52 AM
Shark Racer's Avatar
Shark Racer
Are there settings to modify cranking fuel? I did this on my 87 Corvette to get it to start quicker.
Old Aug 16, 2012 | 02:07 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Yes. Did you add or remove?
The Cranking Fuel table is the amount of fuel injected while the engine is cranking. The base tables should be fairly close for most applications. If this table is too low, an engine may have extended cranking before starting. Increase the value at that engine temperature and see if the startup improves. If an engine starts and is “loaded up” (too rich) with fuel, these values may have to be decreased. Engines always require more fuel when they are cold.
Old Aug 16, 2012 | 02:30 PM
Shark Racer
For the L98 computer, I added. IIRC, the L98 computer had a modifier for fuel amounts based on amount of time cranking.
What is the current setting?
Try adding a little and if that helps, keep going until it stops having an effect and then back off a little bit.
If it doesn't help, as the instructions say, you need to go the other direction.
Old Aug 16, 2012 | 02:51 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
At 70F, about 26 lb/hr
Old Aug 16, 2012 | 04:13 PM
Shark Racer
That actually sounds like a lot... is this a 4 injector system or an 8 injector system?
I think TPI was doing around 10-12lb/hr when cranking, but that's through 8 injectors.
Old Aug 16, 2012 | 04:16 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
It's a TPI manifold with 8 22lbs injectors, the value changes based on coolant temp, from -40 to 260, 20 deg inc.
48.0 46.0 44.0 40.0 34.0 29.0 23.0 20.0 17.0 15.0 14.0 13.0 13.0 13.0 13.0 13.0
Old Aug 16, 2012 | 04:33 PM
Shark Racer
Judging from that I'd say it's some portion of total... so I'd go up and give it a shot.
Only way to know for sure is to experiment. Let us know!
Old Aug 16, 2012 | 04:57 PM
ylose's Avatar
ylose
I agree on adding. Almost seems like your cranking till enough fuel is in there to kick.
Similar to the pump the carb if cold steps.
Old Aug 16, 2012 | 10:13 PM
Learning_Curve's Avatar
Learning_Curve
Have you checked your fuel pressure? Most pumps have a check valve so fuel pressure doesn't bleed down when you shut it off. If either the check valve or the regulator lets the pressure bleed down, then you'll get an extended crank untill fuel pressure builds.
Old Aug 16, 2012 | 11:25 PM
cv67's Avatar
cv67
St. Jude Donor '05
Does yours use the cold start injector?
89 up (didnt) and they crank a tad longer
Old Aug 16, 2012 | 11:31 PM
Shark Racer
This is true, but I switched to an 89 tune in my car (which eliminates the cold start injector) and fixed the long start by going through the process I mentioned above. I doubt Holley's EFI programming or wiring has the capability to pulse a cold start injector.
Old Aug 17, 2012 | 10:53 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
No, new pump, new lines and new injectors. I have the Holley EFI set to 5 second prime, so even if I prime the pump before starting it starts the same way.
Old Aug 17, 2012 | 10:54 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
No cold start, Holley EFI
Old Aug 17, 2012 | 10:55 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
I'll try it out this weekend hopefully
Old Aug 28, 2012 | 11:15 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Added 20% fuel, no improvement, gonna try removing 20%
Old Aug 28, 2012 | 11:36 AM
oldalaskaman's Avatar
oldalaskaman
spin the starter ....faster
Old Aug 28, 2012 | 12:24 PM
Shark Racer
Might try smaller increments as well.
To TPI start, slow?
