headlights vacuum arghhh
Old Aug 20, 2012 | 12:11 PM
glarior's Avatar
glarior
Default headlights vacuum arghhh
80' vette
Are there steps to diagnosing the headlights vacuum. They worked okay then I did the LS1 conversion. Had the lights working at the shop and the next day they never would open. I would not be surprised if that shop screwed something up. They were dumb****
The vacuum lines and all that was installed new ~5-6 years ago. The car has sat for the past year and half.
I have the two diagrams from willcox but everything looks correct.
Currently the driver side lamp will slowly raise... slowly and sometimes not at all.. The passenger side needs to be manually lifted since it only raises enough to put your finger in it to raise it.
Old Aug 20, 2012 | 12:51 PM
scottyp99's Avatar
scottyp99
This should help:
http://forums.corvetteforum.com/c3-t...tem-works.html
Keep the shiny side up!
Scott
Old Aug 21, 2012 | 11:17 PM
glarior's Avatar
glarior
Wow that was beyond helpful. I finally figured out which part is broke and can replace it! thank you for that link.
Yes, keep the shiny side up
Old Aug 22, 2012 | 01:25 AM
scottyp99's Avatar
scottyp99
Before I understood how the headlight actuation system worked on C3s, I thought it was the stupidest system ever designed, but now that I understand it, I am impressed by how simple and ingenious it is. Welcome to the club!
keep the shiny side up!
Scott
Old Aug 22, 2012 | 12:05 PM
78IndyPace's Avatar
78IndyPace
I'm curious. What part was broke?
THANKS!
Jerry
Old Aug 22, 2012 | 12:12 PM
glarior's Avatar
glarior
Actuator Relay, missing filter, bad check valve. So I hope lol. I have a check valve and filter and now trying to order the relay from my local store but their GM parts software is down.
Old Aug 22, 2012 | 12:15 PM
glarior's Avatar
glarior
If it was not for that link sent from above I would have never figured it out. A cheap vacuum pump and that article makes the system so much easier to figure out whats wrong
Old Aug 22, 2012 | 01:28 PM
Mike Ward's Avatar
Mike Ward
Malfunctioning headlights are probably the #1 topic on this board and there is an excellent sticky on it as you've seen.
Too bad it's gotten buried in a 'group sticky' at the top of page. Maybe the kind and gentle mods could move it back out on it's own?
Old Aug 22, 2012 | 01:40 PM
mrvette's Avatar
mrvette
I bought my '72 in '95 and of course the headlights never worked right, so a vacuum relay later and some canister 'witches hat' seals, all installed they worked OK, for a vacuum system, but within a year they back to one up....other straining/slow.....two new witches hat seals, lasted maybe 18 months, at this point I met up with Chris McDonald at McSpeed just down the street from me, and so he was working on the electric conversion....I was waiting for his work to be done, when my decision was made, a damn DEER ran out at night, and claimed both headlight assy's....just junk.....so I went fixed lights as the cheepest solution.....by FAR.....
I found the only way to keep the witches hats sealing on the shaft was to use a thin wire/small tie wrap to keep the rubber from splitting....
that's how I bailed out the second set for some time after until the damn DEER ......
Old Aug 22, 2012 | 02:33 PM
lvmyvt76's Avatar
lvmyvt76
I am am still running all original parts on my 76, so why are you going thru witch hats so quickly??? something is still not right on your system.
To headlights vacuum arghhh
