What is this called? I can't remember
Old Aug 20, 2012 | 01:03 PM
glarior's Avatar
glarior
Default What is this called? I can't remember
What is the splitter piece called. Hoses from the heater core plug into this 'thing' and it goes to the water pump on the LS1. I can't remember what it is called.
Anyone know?
Wish I had a picture
Old Aug 20, 2012 | 01:20 PM
74modified's Avatar
74modified
Hard to say without a pic. Are you talking about a surge tank in the heater line or perhaps the steam vent line?
http://img267.imageshack.us/img267/4241/7d301oh0.jpg
Old Aug 20, 2012 | 01:21 PM
Garys 68's Avatar
Garys 68
Are you referring to the heater control valve?
It closes off preventing hot water from entering the heater core when the AC is turned on.
Old Aug 20, 2012 | 01:49 PM
glarior's Avatar
glarior
Yes! Heater Control Valve!!!!! I can finally order one now haha.
Thank you !
Old Aug 20, 2012 | 02:40 PM
Garys 68's Avatar
Garys 68
Just an fyi. The LS series motors are designed to have coolant running through the heater core at all times. If you have the option, replace the original 2 port HCV with a 4 port that allows coolant to circulate even when it's closed.
Old Aug 20, 2012 | 02:54 PM
glarior's Avatar
glarior
Okay, this just became more complicated....
Is there a diagram showing where the 4 ports will be connected to?
Is there a certain model of car I can use when trying to find the 4 port HCV?
Old Aug 20, 2012 | 03:02 PM
Garys 68's Avatar
Garys 68
Is your HCV vacuum operated?
If so there are a couple options. You can find some part numbers if you search "heater valve" over at the conversion forum at LS1tech.com.
The installation is really simple.
Search for 4-Seasons #74781, it's a 4 port valve used on 95-00 chevy trucks, $14.
Old Aug 20, 2012 | 03:31 PM
glarior's Avatar
glarior
Yes vacuum ... I will check ls1 forum. Thanks for letting me know this
To What is this called? I can't remember
