Using a press to install control arm bushings...
Old May 30, 2002 | 09:01 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Using a press to install control arm bushings...
How do you guys do it? Because of the awkward shape of the control arm, I'm having a hard time stabilizing the arm enough to press the bushings. I was able to install the upper control arm bushings, and one of the lowers, but the last one is really giving me fits.
Any suggestions? Thanks.
Old May 30, 2002 | 09:08 PM
Chuck Harmon's Avatar
Chuck Harmon
Default Re: Using a press to install control arm bushings... (joeveto)
Joe,
Without remembering the specific gyrations, I used blocks of aluminum of different thicknesses bought at a local scrap metal dealer. I also purchased a 3/4" socket drive set, actually 2 sets for about $35 each from Harbor Freight which worked great for pushing the bearings in place and as support blocks.
The hydraulic press I used is a 20 ton also purchased from Habor Freight.
Chuck
Old May 30, 2002 | 09:22 PM
Frank75's Avatar
Frank75
Default Re: Using a press to install control arm bushings... (Chuck Harmon)
The other part that's important is to properly support between the ends of the control arm i.e. so that installation force won't bend the control arm. Different folks have used different stuff: I used some hardwood shaped to fit. Your other option is to pay $20 to the local ga-rage to do it.
Old May 30, 2002 | 10:47 PM
WATTAC's Avatar
WATTAC
I used 1 1/2 inch pipe, or there abouts, cut to length and then cut in half to support the two side of the A arm. The metal is so soft it'll bend if you look hard at it. Even with care I slightly bent one of mine and had to straighten it. Use lub and I've seen recommendations to put the bushings in the freezer before you press them in. Slow and easy is the key.
Andy
Old May 31, 2002 | 08:44 AM
mrvette's Avatar
mrvette
I use a CP711 impact 'hammer' and forgetaboutit...not much reason to ding the arms up, dependng on the tip, but the bushings go in and out really easy....
GENE
To Using a press to install control arm bushings...
