All New Diesel Oil Test Data
Really don't get this, do you? Folks will subscribe to the sticky if they care...and they'll get notified when you update it. No need to post about updates.
And, in the end - still the same claim that ZDDP doesn't matter...and still completely in opposition to every flat-tappet cam manufacturer.
Have you had any manufacturer yet say that one of your recommended SM/SN oils is suitable for flat-tappet cam use...or even contracted them?
Rick is an engineer with a passion for facts on everything....so what you're getting here is the info he has at this stage of his testing..and he keeps adding to it. I can't believe the $$$ and time he's spending on this and tell him all the time his '57 would be finished by now with his 540 installed and smoking tires if he would re-focus..but he loves this stuff. I find it very interesting and it adds to info I've received from some oil industry chemists and engineers over the years.
I encouraged him to let folks know he had added more info since I'm sure there are others like me who don't subscribe to any thread and need a little prodding once in awhile.
I have no doubt these threads have been passed along to some oil folks..and its interesting that no one has offered anyone to add to it. I'd love to see their take on it all. Rick's whole premise is pretty much if you manage to keep the parts from getting together in the first place...it doesn't matter much what other protection is in there. Surely can't hurt to have some added margin from an *emergency* wear protection source like ZDDP....but his tests show that there are many ways to *skin a cat* which is what my oil industry guys have told me for years. They've concocted various blends for 40+ years using all sorts of ingredients to meet the needs. Without a full detailed analysis of every component and the tests they did...it's tough to tell. One that always interested me is that the oil recommenedd for natural gas engines that are modified normal diesel engines with flat tappet cams instead of roller cam in the diesels, actually have very low ZDDP in them. They have cats on them..but so do many diesels these days. Whatever they are using in those oils is protecting the flat tappets (admittedly low rpm, low spring pressure etc).
Hey..Rick still busts on me for using Royal Purple..but my junk looks good when I tear it down!
JIM
JIM
I've encouraged the OP many times to a) contact flat-tappet cam manufacturers with his claims and b) contact the oil manufacturers he recommends for flat-tappet cams to see if they agree with his application recommendations. So far, nada. In general, I wouldn't care about this - but every.single.flat-tappet.cam. manufacturer recommends 1,000 - 1,400 ppm ZDDP, period.
A good engineer doesn't rely on single-dimension testing or their own beliefs - they validate with other engineers and information sources, and use industry-standard test methodologies...as one oil vendor (Brad Penn) notes on another thread:
http://speedtalk.com/forum/viewtopic...art=90#p376742
"I would like to begin by stating unequivocally that the test utilized for comparison of the different motor oils is NOT an industry accepted test and has not been peer reviewed or validated by any certification body such as American Society for Testing and Materials (ASTM), American Petroleum Institute (API) or the American Chemistry Council (ACC). Therefore, I do not consider the test data valid. I should note that non-ASTM associated bench tests are not the most reliable indicators of field performance.
Additionally, I think the primary concern I had with the information is that one cannot effectively measure “load carrying capacity/film strength” in a 30 second test that is NOT considered a standard industry test with the rigorous inter-laboratory round robin studies needed to generate the measurement system precision statements. The gold standard to evaluate the different lubricants would be controlled engine testing in which cam lobe loss is measured as well as piston ring loss. The API Service Category SM and the latest SN oils listed contain friction modifiers (friction modifiers are added in API SM & SN oils for fuel economy benefits) which are one reason why they might perform better in a 30-second “break-in” period. It is my opinion that a 30-second test is not a proper performance test of the load-carrying capacity of a lubricant in boundary lubrication regimes."
What I said was that oil engineers have always had many ways to create the necessary wear protection as well as all the other attributes needed for a particular blend. ZDDP is not the only thing that can save parts. Just throwing additional ZDDP or anything else into an oil blend may or may not create the desired outcome.
The things the Brad Penn guy mentioned about the way their oil *sticks* to parts is definitely a feature I see in their product. I've always liked that if for nothing else having an oil film already in place is better to me than having a quick flowing oil that runs off after shutdown. You can lay a part on the table with Brad Penn on it and 2 mos later it will still be *wet*. I don't know what's in their blend to do that...but it does. I used to work on a nitro drag car that had no upper end oiling at all. Right after setting valves we would soak the valvetrain with Brad Penn and stick the covers on. Never had any troubles with it. Look at many oils today (look through oil fill hole or pull a cover) and the parts are near bone dry after sitting overnight.
There was a guy on the forums a few years ago running Walmart Tech 2000 in his 7 second BBC dragster. He insisted on leaving the oil in the entire season and then checking the bearings every year. They always looked new,,which means that whatever film strength that oil has is sufficient for what he was doing and the simple oiling system was working fine. It was a roller motor..so it doesn't tell us anything about flat tappets wear.
I personally don't think I've ever actually seen an issue with an oil itself that I knew of...it was a mechanical problem. Ford did use to fuss a lot about using oil that was too thick in some of their gas engines.
Anyway,,,I like the testing whether the conclusions are the end all/be all last word or not. A good engineerr with any marketing background at all would get on here with some real tech discussions to educate the masses.
Isn't this stuff fun?
JIM
JIM
http://www.zrxoa.org/forums/showthre...a-T6-Synthetic
Note the SM rating....................
One thing i'm unclear on is what is the primary mode of protection. I would think that would be film strength. Once that breaks down then you are on ZZDP as backup protection? Startup mode when there is no oil coating would be one mode for ZZDP? On a cam with moderate ramps and moderate spring pressure do we ever really need the ZZDP?
http://www.bobistheoilguy.com/oilshear.htm
I have explained why in great detail numerous times on the many threads on this and on the oil sticky. I have answered your questions above. Not repeating myself here again. If you havent read it yet, we have a search function. Or click on my name and open my posts and go through them if you need more detail.
The simple fact - not opinion - is that all of these manufacturers specify 1,000+ ZDDP for flat-tappet cams. I post on these threads to ensure folks are aware that 540 RAT's guidance is counter to those manufacturers - and they can make up their own minds from there.
Which brings me to "following him around" - this is by his choice; he was provided a sticky for his testing, something not done lightly by the Mods, which he chooses not to use. All the debate could be there, but instead he chooses to post and repost, and now even cross-posting from other sites.
This is a community, and folks are welcome to post what they like, where they like. It gets heated sometimes, and it gets personal sometimes. There's good information posted here, and utter BS. The Mods reign lightly over the top, hearding cats where they need to. In the end, it works very well. If you don't like information, ignore it. If you don't like a poster, that's what the Ignore function is for.
