LS1 Aircraft engine
Old Aug 22, 2012 | 09:13 AM
jcloving's Avatar
jcloving
Default LS1 Aircraft engine
I read on wikipedia that LSx engines are sometimes used in small aircraft. I mentioned this to a flying friend of mine and he sent me this link.
For all the LSx guys, check this out:
http://www.geareddrives.com/FWF_RV_10.htm
Old Aug 22, 2012 | 09:43 AM
Corey_68's Avatar
Corey_68
I saw a cessna with LS1 a couple years back, pretty .
Old Aug 22, 2012 | 09:59 AM
jnb5101's Avatar
jnb5101
i've been told by engineers that automobile engines are not suitable for aircraft use for two major reasons. one is the extended time the engines are run at wot at take off. would any of us trust our lives on whether our engines would run repeatedly (hundreds of cycles) at wot for 5 minutes on a dyno? i wouldn't. and second, the harmonic vibrations developed by the engine are damped by the automobiles drive line. in an aircraft the propeller adds to the harmonics and causes crank shaft failure. in my wild and woolly youth i considered a home-built aircraft and talked to an aircraft engineer i knew-he emphatically said "no".
there's a reason aircraft engines cost $25K.
Old Aug 22, 2012 | 10:46 AM
billla's Avatar
billla
St. Jude Donor '14
Just about every type of engine has ended up in an experimental aircraft somewhere.
I was involved in the Papa 51 Thunder Mustang company, using a Ryan Falconer V-12 with a custom gear drive - quite a ride
Automobile engines are perfectly suitable for aircraft use when properly configured and installed. And experimentals are a riot
Production general aviation aircraft engines cost well over $25K because of liability and certification - not because they're any higher quality or safer. They're for the most part low compression, low technology, horizontally-opposed air-cooled 6 cylinder engines making very low power per CID.
This is my bird with one of those low-tech engines; I figure it's OK to share a non-automotive toy given the topic
Old Aug 22, 2012 | 01:58 PM
Garys 68's Avatar
Garys 68
As long as we're talking about odd LSx applications, how about a marine engine.
No, not that kind, a supercharged outboard.
http://www.seven-marine.com/motors/p...nd-technology/
Old Aug 22, 2012 | 02:02 PM
stpman's Avatar
stpman
And yet they're still building small aircraft using old Corvair flat 6 engines
Old Aug 22, 2012 | 03:01 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
That's a beauty, must be fun, a 50cal sticking out of that hole in the front would be really
As for experimental engines and homemade engines you couldn't pay me to go for a ride in one. We can't even get our motors to run half decently on four wheels on the ground a lot of the time, let alone flying around with a prop attached to my 427ci, no thanks. Unfortunately I knew a couple of guys who are no longer around after building "experimental" airplanes in their garages many years ago.
The only way is an aircraft engine that has been looked over and tested by an airplane technician after a different technician has already passed it. Watch out for Chinese parts in this field of mechanics too
Old Aug 22, 2012 | 03:45 PM
billla's Avatar
billla
St. Jude Donor '14
Thanks It was a liasion plane and never armed...and that hole is the air intake!
I've flown a bunch of experimentals...and some are more experimental than others.
Aircraft engines are used for the vast majority, but there are a lot out there with Subaru engines and other weirdness. They're typically a ball to fly - fast, light on the control and aerobatic. Heck, my bird is a 1948 - so it ain't exactly new
Old Aug 22, 2012 | 06:09 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default This is link a bit innapropriate.
FYI Bud Warren, the designer of that reduction drive, crashed and died with his daughter/business partner. Though he was an degreeded engineer and i really admired his effort his website is not an appropriate to promote - at least thats how i feel.
May Bud rest in peace,
cardo0
Old Aug 23, 2012 | 08:07 AM
U17's Avatar
U17
http://www.v8seabee.com/
Old Aug 23, 2012 | 10:40 AM
jnb5101's Avatar
jnb5101
it's your life. spend it as you wish.
Old Aug 23, 2012 | 11:33 AM
billla's Avatar
billla
St. Jude Donor '14
Old Aug 24, 2012 | 05:48 AM
richiev88's Avatar
richiev88
Nice to have a "bird". Is it Aerobatic rated ?
Did my plane drivers ticket years ago, not flown for ages, miss it, did my Aero rating just after PPL, best ride you can take friends on.....ever
To LS1 Aircraft engine
