Water pump bolt question
Old Aug 22, 2012 | 09:02 PM
spedaleden's Avatar
spedaleden
Default Water pump bolt question
I just put in electric fans (Dual Spals) I need the bolt size for the pulley that mounts to the water pump. I tried a M8 X 100 but it stops after 5 turns.
By any chance is the water pump hub like a pipe thread?
Any help appreciated.
Old Aug 22, 2012 | 09:06 PM
'75's Avatar
'75
Old Aug 22, 2012 | 09:37 PM
spedaleden's Avatar
spedaleden
Originally Posted by '75
5/16-24
Is this the size that bolts to the fan or the size that goes into the water pump. The studs have two different size threads on them.
Old Aug 22, 2012 | 09:39 PM
Mike Ward's Avatar
Mike Ward
That's a metric bolt. Won't fit.
Old Aug 23, 2012 | 08:20 AM
'75's Avatar
'75
The thread for the water pump hub is 5/15-24, fine thread. The studs are usually fine thread going into the hub and then take coarse thread nuts to hold the clutch to the water pump, at least that's how it is on the ones I've seen.
Old Aug 23, 2012 | 05:04 PM
spedaleden's Avatar
spedaleden
Thanks just wanted to be sure
Thanks again
To Water pump bolt question
