Amps
Old Aug 23, 2012 | 06:03 PM
zambo75's Avatar
zambo75
Default Amps
Drawing about 5 amps of power when cars off,battery will die in about
48 hrs! Any help where to start or how to find a draw,any info will help.
1975 c3 vette 350 5.7 stock
Old Aug 23, 2012 | 06:09 PM
johnt365's Avatar
johnt365
You can narrow it down to a system or so by testing for continuity at each fuse in the fuse box. Once you find the fuse with current you know its somewhere in that circuit.
When did this issue start for you or has it been like that since you got the car. If you can pin point a time it started, then look for what might have changed to possibly cause the draw.
If not a daily driver you may think about a battery disconnect and a trickle charger .
Old Aug 24, 2012 | 07:53 AM
KenSny's Avatar
KenSny
Drawing 5a with car turned off: Something is shorted to ground.
Don't waste your money on a tickle charger or a battery disconnect UNTIL you find the problem. Then add extras.
Old Aug 24, 2012 | 09:56 AM
Vette5.5's Avatar
Vette5.5
5 amps is a very large draw, and a fully charged battery won't even make it a 1/2 day. You need to find the problem, as if the battery goes totally dead, it's usually a goner for good. You can connect an ammeter inline for testing, or get hold of a clamp on DC ammeter, while pulling fuses, or wiring connections. Having another person to help, is a good idea. Make sure you remove hood and dome light bulbs when doing this.
To Amps
