Heating up
Old Aug 24, 2012 | 10:50 AM
Colie111's Avatar
Colie111
4th Gear
Default Heating up
I have a '78 L48 Original car. My problem is when the car heats up it will not start. Let it sit and cool down and it starts??? I have replaced the Battery and the Alternator.
Old Aug 24, 2012 | 11:18 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Starter and solenoid are absorbing engine heat, very likely from the exhaust manifold/pipe. It the stock heat shield in place?
Old Aug 24, 2012 | 11:51 AM
lvmyvt76's Avatar
lvmyvt76
tell us more of the problem, like no crank when hot, or slow crank when hot,etc. That way we can help more.
Old Aug 24, 2012 | 12:13 PM
tonystar1's Avatar
tonystar1
I was thinking ignition coil, but yeah, need more data.
Old Aug 24, 2012 | 08:17 PM
Colie111's Avatar
Colie111
4th Gear
The Car does nothing No sound for at least a couple of hours when it cools down.
Old Aug 24, 2012 | 08:18 PM
Colie111's Avatar
Colie111
4th Gear
Old Aug 24, 2012 | 08:49 PM
texas jim's Avatar
texas jim
Possibly a bad starter. Get it checked. When the starter gets hot, it shorts out and when it cools off, the epoxy hardens and separates the shorting wires again, in either the armature or stator. I'm guessing that's it.
Old Aug 25, 2012 | 05:02 PM
Colie111's Avatar
Colie111
4th Gear
There is no crank or noise of any kind. But if I boost it it cranks and starts just fine.
Old Aug 25, 2012 | 10:24 PM
texas jim's Avatar
texas jim
starter.
Old Aug 25, 2012 | 10:44 PM
74modified's Avatar
74modified
If it was just the starter, the solenoid would click. No sound at all means you have no solenoid function. The solenoid could be bad, but a common problem is heat soak causing the solenoid coil to be weak magnified by old switches and wiring.
http://forums.corvetteforum.com/c3-t...sometimes.html
To Heating up
