Repairing Internal Plastics
Old Aug 24, 2012 | 11:34 AM
EngineerJay's Avatar
EngineerJay
Default Repairing Internal Plastics
I am planning to redo the wiring in my '71 this winter, already have the harnesses. From previous work under the dash, I know several of the plastic parts are cracked or broken. Is there a way to fix these? Specifically the area where the vacuum overrides are attached to the tach/speedo dash and the shift console area.
Thanks,
Jay
this is an older picture, but the mounting location is practically non-existent.
Old Aug 24, 2012 | 11:40 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The substrate for the stock panels is a type of resin material. I have never considered it to be fiberglass and it would not meet my definition of a hard plastic.
Polyester resin will repair areas of damage, i.e., missing threads for mounting points.
Good luck.
