need help with manual trans
Old May 31, 2002 | 08:07 AM
zzrck's Avatar
zzrck
Default need help with manual trans
I bought a t10 trans to replace my muncie that was completly dead. the guy was using it in his 78 vette. The problem is he didn't send me the yoke with the trans and when I called back he told me he didn't know where it was. It's not a 78 trans and I don't know wich yoke to use and where to find it. so if anybody could help I would greatly appreciate.
the output shaft has 16 spline and is the same size as my old 69 muncie
there was those inscription:
on the tailshaft housing 2-10-65 T10-7D W.g. div. R1
on the case T-10D-1
and just beside the side cover G6 62
I've seen that the powerglide use a 16 spline yoke but can I use it?
Old May 31, 2002 | 12:24 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: need help with manual trans (zzrck)
You can use a powerglide yoke but it may use a smaller u-joint. Hy-bred joints are available that combine the small and large caps into one joint.
Old May 31, 2002 | 01:04 PM
zzrck's Avatar
zzrck
Default Re: need help with manual trans (burners)
are you sure the shaft diameter are the same?
To need help with manual trans
7d, div, r1, t10, wg
