Tachometer speedometer not working ?
Old Aug 28, 2012 | 11:21 AM
Batman0913's Avatar
Batman0913
Default Tachometer speedometer not working ?
Nothing is working on the cluster or dash gages no RPM or Speedometer.
Its a 1981 I was told will need to purchase the hole unit...?
Is this true?
Plus I see they sell a circut board for the Tachometer alone will the board make the speedometer work as well ?
In other words are they conected...?
Thank you !
Old Aug 28, 2012 | 11:49 AM
gbvette62's Avatar
gbvette62
The speedometer is cable driven, while the tach is electronic. The printed circuit could effect the tach, but not the speedometer.
Old Aug 28, 2012 | 11:55 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Batman0913
...Nothing is working on the cluster or dash gages no RPM or Speedometer...Its a 1981 I was told will need to purchase the hole unit...?...Is this true?...
Possibly not, depending on what the problem might be.
...I see they sell a circut board for the Tachometer alone will the board make the speedometer work as well ?...In other words are they conected...?...
No.
Has the dash been out of the car?
Old Aug 28, 2012 | 11:02 PM
Batman0913's Avatar
Batman0913
yes it was taken out everything was conected How ever I did not new they were seperate
thank you all for the info. will work on it this week end..!
To Tachometer speedometer not working ?
