77 C3 running hot HELP!
Old Aug 28, 2012 | 02:03 PM
xkeots's Avatar
xkeots
Default 77 C3 running hot HELP!
Hi,
On my 77 C3 I just took it straight home as the temp gauge started shooting up and I wanted to make sure that the gauge was working. (it was)
In June I put in a brand new water pump, all hoses (3 to heater core separated by new heater vacuum switch and 2 main and new hoses to fill canister), all new anti freeze, thermostat and pre flushed out and back flushed) the radiator and system.
When I got home, I just got my IR temperature gun and checked the car out.
This is how it read.
Top Hose off radiator 210
Lower hose off radiator 174
Water pump body 214
Can I have a defective thermostat?
Help please.
Jack
1977 C3 L-82
Old Aug 28, 2012 | 02:07 PM
MelWff's Avatar
MelWff
why do you think you have a problem,with a 195 thermostat, that sounds right, what did the gauge inside the car read? what has the gauge read prior to today? did you check if your fan clutch is worn?
Old Aug 28, 2012 | 02:17 PM
xkeots's Avatar
xkeots
Car usually kept a solid 180-190 for the past 3+ years driving or in traffic (since I have owned it).
I had to replace the water pump as it sprung a leak, so I replaced all hoses, etc too. The new one kept it a solid 170-180 with a/c on all summer till today. It is a 180 thermostat. I was at a light 2 blocks from my house when I saw smoke coming from my ac ducts that smelt like anti freeze but nothing when I opened the hood and no leaks from core. The inside gauge was in the 210-220 range
I didn't check fan. (what's the best way to do that?)
I have 2 fans with clutches in basement from my 67 GTO.
I will wait till car cools.
Jack
Old Aug 28, 2012 | 02:21 PM
MelWff's Avatar
MelWff
so are you saying you installed a 180 thermostat? If you have smoke coming from a/c ducts that smells like antifreeze you may have a heater core leak. Check the carpeting on the passenger side footwell for antifreeze.
For the fan, with the engine off, try spinning it by hand, it should not turn more than maybe a half to full turn when hot. When cold maybe a full turn. In addition look for excessive play by grapping opposite fan blades and moving and signs of leakage of fluid from clutch.
Old Aug 28, 2012 | 03:02 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by xkeots
...The inside gauge was in the 210-220 range...
Normal.
Old Aug 28, 2012 | 04:17 PM
REELAV8R's Avatar
REELAV8R
My 77 with the original fan set up ran 220 all the time. If the air was on and at highway speeds 230+.
Now I have electric fans and it runs 185 in town and still 210 on the highway or if the a/c is on and 95+ out side 230. The 230 is worrisome but not anything it can't handle.
So 210 to 220 I wouldn't worry about. The thing that puzzles me is how you got 180 with stock fan configuration. Maybe your temp gauge was wrong in the past? Ever double check that 180 temp with an IR gun?
I guess assuming nothing else is different I would look to the fan clutch or the "new" water pump. You never with Chinese quality these days.
Had another thought. Did you notice any performance changes? I'm thinking failed vacuum advance diaphram causing ignition timing to be come suddenly retarded at cruise or low throttle openings.
Old Aug 28, 2012 | 09:37 PM
xkeots's Avatar
xkeots
Back in the day,
my 69, 72, 76 & 77 all ran at 180 all year long, so I am going by that number.
My inside gauge was the same temp as my upper large hose off the radiator.
Why is my lower hose about 30 degrees cooler than my upper?
Jack
Old Aug 29, 2012 | 08:03 PM
lvmyvt76's Avatar
lvmyvt76
is that where it pulls the cooled water from the radiator to run thru the motor and then back to the radiator? It should be cooler??
Old Aug 29, 2012 | 09:23 PM
74modified's Avatar
74modified
Jack
If you smell antifreeze, could be heater core leak (in car). You didn't say if coolant level was low = leak. You could use you IR gun to check temp while looking for circulation, this will tell you if thermostat is not opening.
Old Aug 30, 2012 | 05:37 PM
xkeots's Avatar
xkeots
Please look at my original post.
It has all of the IR readings!
The anti freeze (of course) is full and no leaks from core.
Jack
Old Aug 30, 2012 | 10:21 PM
REELAV8R's Avatar
REELAV8R
Back in the day,
I guess I'd start by pulling the thermostat and see what happens. Then check timing to see if something has changed.
Lower rad hose cooler after water passes through radiator.
Can't explain the the "smoke" from a/c ducts that smells like antifreeze unless it's leak in or near the heater heat exchanger (core).
Old Aug 31, 2012 | 04:34 AM
noonie's Avatar
noonie
Yes it does sound like the tstat is not opening fully or the fan not pulling enough..
You're coolant out temps seems a little low and the pump temp is too high..
They should be really close with the pump being just a tad higher. Maybe 5°
Seems like it's mostly circulating thru the bypass in the pump.
You should get a temp diff of about 20-30 degrees on the oem rad
Current tstats are notoriously prone to failure.
Old Aug 31, 2012 | 07:27 AM
74modified's Avatar
74modified
Jack
I read all of the posts. You didnt say the coolant level was full. I was trying to comunicate (not very well, I guess) that you should open the radiator to look for circulation (that you wouldnt have with a stuck thermostat) when the IR readings say the thermostat should be open.
Old Aug 31, 2012 | 03:50 PM
xkeots's Avatar
xkeots
Please forgive me. I am terrible at typing and I usually think that I am understood if I don't dot every I and cross every T.
The smoke came out of the A/C duct 5 minutes before I shut down the car. I was running the car with the windows open and 10 minutes before I put the A/C on and I saw the smoke that smelled like anti freeze. I then shut it off and drove home. I just wanted to cool down a little as it was 95 degrees outside and the gauge was close to the red. No leaks and when I opened it, the rad was topped up.
When I got home the upper rad hose was in the 210 - 215 range and the lower rad hose was in the 174-180 range with an IR temp gauge.
I did have to wait close to 8 minutes from the time I shut the car down to the time I found the IR gun and used it.
So the temps must have dropped down a little.
I am totally thinking that I might have not changed the old thermostat on the 77 as I did my 63 & 77 on the same day.
The 63, I know that I flushed and changed everything, due to it being in the high 90's that day, it does weird things to all of us and I did find a Stant 180 in my tool box in it's box.
I might not have changed the 77.
That could do this, am I right?
Jack
77 C-3
Old Aug 31, 2012 | 04:09 PM
74modified's Avatar
74modified
This doesn't necessarily mean the thermostat is stuck. The upper hose is hotter when thermo opens and the hot coolant flow to the rad. The bottom is returning (hopefully) cooled liquid to the engine. Many times a stuck thermo will cause overheating coolant in the engine (boiling) and with no escape out the top it will back out into the bottom of the rad. This could result in a hotter bottom hose and cooler top hose. All this said, you could change it out quicker than reading thru all of this.
Old Sep 2, 2012 | 06:51 PM
xkeots's Avatar
xkeots
Going to my supply store Tuesday after holiday.
Radiator boiled out, motor flushed, fan good, new anti freeze and water pump. All hoses replaced. Rad topped up and side can at full line. No leaks anywhere.
I will do thermostat again.
I am stumped
Jack
Old Sep 2, 2012 | 07:26 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Either way, you should NOT have smoke OR anti-freeze smell from the ducts. That indicates a heater core going bad. You can simply by pass that with a hose. Then re-check to see if it still smells.
To 77 C3 running hot HELP!
Old Sep 6, 2012 | 02:41 PM
xkeots's Avatar
xkeots
Hi All,
I am sorry, Mia Culpa-please forgive me.
It happened again and there was a light smoke coming out of the center ducts and I did smell anti freeze. I quickly pulled over and I saw that the fan was blowing a small amount of green from the cap towards the motor and that's what I smelled inside the car.
I just bought a new correct pressure cap too. The one on the car had a cracked seal under the cap.
I think that the smokish air is a bad O ring from going to 134 from R 22 without changing anything. I did a gamble by just changing the 2 hi & low pressure caps to 134. It held up all summer and is still blowing cold air in 90 degrees.
When I get the money I will do it correctly, but i am very cash tight as I have my 67 GTO convertible almost ready to lift off frame too.
I am using a pump and taking out of the radiator top about a gallon of green so I can replace the thermostat while the fluid is below the thermostat housing.
Fan is not wobbly and good.
Jack
Old Sep 6, 2012 | 08:27 PM
jb78L-82's Avatar
jb78L-82
In the last 30 years I have known 2 cars that had "smoke" coming from the A/C ducts-74 L-82 corvette and a 72 caprice with a 350. Neither was a bad heater core! Both times, the thermostat was stuck closed and the engine was overheating.
Old Sep 8, 2012 | 04:54 PM
xkeots's Avatar
xkeots
Just changed thermostat. I also noticed quite a lot of leaves between the radiator and condenser that needs cleaning. Possibly blocking air flow.
Car sat idling for 20 minutes and inside gauge was at 12 o'clock once thermostat opened.
I saw smoke immediately from A/C duct, it has to be from the humidity outdoors. No smell just like when you breathe outside in winter, you get a smokish cloud from your mouth, same.
Tomorrow I will clean out radiator front and drive it a bit and see.
Jack
