Rectangular/Oval port debate.
Old Sep 11, 2012 | 09:27 AM
  #41
Cstraub69's Avatar
Cstraub69
Originally Posted by roscobbc
It would be interesting to examine the theory behind port mis-matching - is improved turbulence a benefit?
The addition of tumble to the port some feel atomizes the fuel and air better. Laminer flow is the under current of air that "carries" the air fuel along the port. It's like riding a skate board. Some will allow a ledge on the floor of the port where the intake meets the head. The head side will have about a .125" tall ledge. This ledge ramps up the laminer flow mixes the air and fuel allowing for "tumbling" of the air fuel molecules. This mixed up air makes better power. This line of thinking is especially used in methanol based engines.
Old Sep 11, 2012 | 02:43 PM
  #42
roscobbc's Avatar
roscobbc
Originally Posted by Cstraub69
The addition of tumble to the port some feel atomizes the fuel and air better. Laminer flow is the under current of air that "carries" the air fuel along the port. It's like riding a skate board. Some will allow a ledge on the floor of the port where the intake meets the head. The head side will have about a .125" tall ledge. This ledge ramps up the laminer flow mixes the air and fuel allowing for"tumbling" of the air fuel molecules. This mixed up air makes better power. This line of thinking is especially used in methanol based engines.
Very interesting - I can see the logic where 'wet' alky based fuels are concerned - oddly my lad is building-up a 390 cu in Ford engine for his Tbird and debating whether to use original low riser 427 heads or - Edelbrock heads which have far smaller intake ports than CJ or 427 heads and therefore a port mismatch which seems to be far more significant than what we have been discussing. He will be using an early dual quad FoMoCo inlet with one reverse mounted Holley. Surprisingly this is dual plane! - wonderfully complex casting which by nature of its design must have quite high port velocities unlike open dual quad manifolds.
Old Sep 11, 2012 | 03:03 PM
  #43
Cstraub69's Avatar
Cstraub69
I just cammed Ed Morel's 489CID FE Nostalgia Engine earlier this year. We went with a set of Blue Thunder Medium Riser heads that Barry Robotnic massaged. We managed 839HP out of the ol girl.
If you want an opinion, go with the Blue Thunder heads. AT has a killer piece.
