15x7 Wheels on a Vette?
Help! I've got a set of 15x7 rims. I would like to mount 255's in the rear and 235's in the front. Will this work? Open to comment and suggestions.
From: Godspeed Mikey Hogsmak Invitational Spring Skyline Drive Corvette Cruise
Cruise-In I Veteran
Cruise-In II Veteran
15X7 I think they were 67-68, 69 went to 15X8. I have 265's(Ithink that is equiv. to 70 series) all the way around on my 69.
Cruise-In I Veteran
Sorry, what I was trying to say is I have the equivelent to F70's on my 15X8 wheels if the 255's are thinner profile than mine they should work just fine in 15X7. Do you know what the 255's are equal to in the old style?
Cruise-In I Veteran
I will check with my tire retailer on Monday also. I can get BFG T/A's 255-60-15 for $120 pair not including mounting and balance. Thanks for your help guys, if anyone has further input into this discussion, it would be appreciated! :)
[Modified by Brian, 10:40 PM 5/31/2002]
Be sure that your front suspension is in good shape. If there is any wear, one or both of the front tires may rub during a hard turn. I learned this the hard way after going from P225 70R15's to P255 60R15's. :cry
If you are only going to a 235 on the front, I don't think there will be any problem. Post some pics when you get them!
:chevy
:chevy
Brian, welcome to the 7" outcast club :)
I'm currently running 245/60/15 all around on the stock '68 7" wheels. They fit the rim fine, and I think that the 255 would fit fine as well. The only problem is that my 245s rub very slightly on the frame at full steering lock in the front. Nothing to worry about, but the 255s might be a little worse.
-Joe
-Joe
