Trouble setting the timing
Old Sep 6, 2012 | 03:44 PM
jdbuddy's Avatar
jdbuddy
Default Trouble setting the timing
I want to check/set the timing on my '79 but the harmonic balancer does not have any marks on it (completely worn off over the years). I cannot even find a grove cut into it for the mark. The timing tab is attached to the block, so that is ok.
So I have to find tdc to set the mark. I bought a tdc indicator, but I am not able to rotate the engine by hand to use it. I do have an 18" breaker bar and the right hex head socket, but with all the belts, hoses, and the fan, I cannot get a good hold to rotate the engine.
I read that a tdc whistle will work and you can use the starter to bump the engine over to use it. Anyone used one of these? After you hear the whistle, do you set the mark under the 0 degree of the timing tab?
Old Sep 6, 2012 | 04:15 PM
Jedi926's Avatar
Jedi926
PM "Billa, he recently suggested 2 tools to help someone find TDC. I think the total cost of the tools was below $30. His suggestion may help you also. Good luck.
Old Sep 6, 2012 | 04:16 PM
MelWff's Avatar
MelWff
I know it's more work but if you remove all the spark plugs you should be able to turn it. Amazed that you cannt see the groove in the balancer. Have you tried removing the distributor cap and bumping the engine over till the rotor is pointing to either the number 1 or number 6 cylinder wire location. At that point the groove should be near the tab.
Old Sep 6, 2012 | 05:01 PM
scottyp99's Avatar
scottyp99
If your dampener is so worn down that the timing mark has "worn off", you need a new dampener, badly.
The mark is there, probably full of crud. Find it, and clean the crud out.
Keep the shiny side up!
Scott
Old Sep 6, 2012 | 05:05 PM
wiguy's Avatar
wiguy
Had the same problem on my '79. cleaned te damper and a little white paint in the groove fixed it.
Old Sep 7, 2012 | 10:13 AM
jdbuddy's Avatar
jdbuddy
You guys were right. I had to bump the starter several times, degreasing each time. I finally found the groove.
It is now painted white and shows up nicely with the timing light.
Thanks for the help.
Old Sep 7, 2012 | 04:06 PM
scottyp99's Avatar
scottyp99
So, how's the timing look?
Scott
Old Sep 7, 2012 | 05:55 PM
lvmyvt76's Avatar
lvmyvt76
if yo are trying to turn the motor over with the breaker bar on the bolt in the balancer, you can strip this bolt out, be careful.
Old Sep 7, 2012 | 07:19 PM
scottyp99's Avatar
scottyp99
Try something like this for turning the engine over.
http://www.summitracing.com/parts/WMR-W80510/?rtype=10
Scott
Old Sep 8, 2012 | 11:28 AM
jdbuddy's Avatar
jdbuddy
Looks ok. Initial around 15 and total in the low to mid 30's with the vacuum advance plugged up.
Old Sep 8, 2012 | 03:41 PM
scottyp99's Avatar
scottyp99
Sounds good. Are you using Lars' article for setting your timing?
Scott
To Trouble setting the timing
