Clutch chirping ?
Old Sep 7, 2012 | 02:52 PM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
Default Clutch chirping ?
when the clutch pedal is released, there is a chirping noise. If I apply slight pressure on the pedal, it goes away.
Clutch bearing?
Old Sep 7, 2012 | 02:58 PM
MelWff's Avatar
MelWff
with the engine off, how much play do you have in the clutch pedal measured by pressing down on it with your hand till you feel the throwout bearing touching the clutch cover fingers? Typcially you should have about 1 1/2"
Old Jul 16, 2013 | 11:48 AM
moonsteel's Avatar
moonsteel
Holley HP EFI w/TPI
I'll check.
Old Jul 16, 2013 | 04:16 PM
BBCorv70's Avatar
BBCorv70
I had the same issue. It sounded like the throw bearing riding on the pressure plate. I backed off on the adjustment, allowed more free play so the bearing wouldn't be in constant contact with the pressure plate. Haven't heard it since..
Old Jul 16, 2013 | 04:21 PM
MelWff's Avatar
MelWff
10 months later?
Old Jul 16, 2013 | 04:22 PM
qwank's Avatar
qwank
Originally Posted by MelWff
10 months later?
people get busy with other things sometimes
To Clutch chirping ?
