engage starter pinion only?
Old Sep 7, 2012 | 08:17 PM
jnb5101's Avatar
jnb5101
Default engage starter pinion only?
i'm transplanting a 427 auto into my 72 4 speed. i want to check the starter alignment before i finish the install because of noise while cranking. is there a way to engage the starter pinion without having the starter run? the starter appears to be almost new.
Old Sep 7, 2012 | 08:54 PM
MelWff's Avatar
MelWff
I havent seen the exact location myself but supposedly you can insert a screwdriver into a slot and force the pinion out
