Harmonic Balancer Installation
Old Sep 7, 2012 | 09:30 PM
rodney25's Avatar
rodney25
Default Harmonic Balancer Installation
Hi All,
I'm trying to install the harmonic balancer. When I went to the local auto store for timing chain gasket kit, there is a thin metal cylinder that seems to fit over the front cone of the harmonic balancer, but when I took the balancer off there was no metal cylinder over the front cone. The metal cylinder is so thin that if I try to install it on the harmonic balancer the metal starts to bend. My question is how do you install the harmonic balancer, is this thin metal cylinder needèd? What is for?
Thanks.
Old Sep 7, 2012 | 09:41 PM
speedreed8's Avatar
speedreed8
that is a sleeve to install on the balancer if it has a wear groove in it from running on the seal. it can be installed if you heat it some. if the old balancer has no wear groove you shouldnt need it. i've installed them before by heating the sleeve in the oven and put the balancer in the frig. it'll slide right on. should have a small tool to install it with
http://www.oreillyauto.com/site/c/de...2288&ppt=C0332
Old Sep 7, 2012 | 09:48 PM
rodney25's Avatar
rodney25
First, thank you for responding so fast.
Thank you for the info, mine is dented so I think I will need to buy a new kit,. Don't think they sell it separate. Do you know what the technical name for it is?
Thanks again.
Old Sep 7, 2012 | 09:51 PM
speedreed8's Avatar
speedreed8
i always called them redi-sleeves, look at the orielly link i posted they do sell them seperately
To Harmonic Balancer Installation
