Front Toe:
VBP - Driver ____1/32 IN - Slalom 3/16 OUT_______-Track 0-1/16 OUT
GUL - Driver_1/8-3/16 IN - Slalom 1/8 OUT - 1/8 IN -Track 0-3/16 IN
My Front Toe is 1/16 IN which is in range for Driver, Slalom or Track according to Gulstrand but is out of spec on all according to VBP.
Rear Toe:
VBP - Driver 1/8 IN______- Slalom 1/8 - 1/4 IN_____-Track 1/8-1/4 IN
GUL - Driver 1/16 -1/8 IN_- Slalom__0 - 1/4 IN_____-Track 0-1/4 IN
My Rear Toe is 3/16 IN which is in the range for Slalom or Track according to both VBP and Gulstrand. It is out of range for Driver according to both Gulsrand and VBP.
I intend to use the car for cruising with an occasional autocross/slalom just for excitement. A test drive told me that it tracks fine and I didn't notice any bad handling characteristics on straight or curvy roads, but I haven't had it on the highway yet.
So the question is: Would you change my alignment and more importantly WHY are you recommending a change?
I'm not too concerned with tire wear because they will probably need replacing due to age before I wear out the tread. I also think I will leave the rear toe as it is due to the relative difficulty in adjusting it, but I will adjust it if somebody has a compelling reason.
The Vette is a '74 small block and has a Rack Attack steering system.
You do realize when VBP says 1/32" that is per wheel for a total of 1/16"? They also say in the comments below you can go as much as 1/8" total, 1/16" per wheel, to correct for "darting". On yours when yoy say you have 1/16" is that per wheel or total?
On your rear same question, you say 3/16", per wheel or total?
all alignment specs are a starting point, you then adjust from there to your preferences and driving style. E.g. you want nice, worry-free, track down the road no matter what manners, 1/16 out is a good place to start. You want the car to quickly turn in, 1/16 in is a good place to start.... BUT, while cars at the factory can be set exactly the same, 40 years of settling, updates or changes to the suspension will require you spend some time dialing in your suspension. Once you get to that point (where you set your own specs), then you'll start setting for specific tracks - need more top speed? zero the alignment.
My car, lowered 1 1/2", different springs front and back, tubular control arms, changed camber/caster.... the specs that any of the manufacturers say are merely suggestions.
After you dial in your toe-in, then you can start playing with camber and caster (high speed handling)
(((After you dial in your toe-in, then you can start playing with camber and caster (high speed handling))))
this needs to say after you dial in your camber and caster, set your toe. and then every time you make a change to either your camber or caster, reset the toe in specs. cause every time you change them ,it changes the toe in
hope this helps
Who makes that little tool you have there and what is the part number? not coming up with anything in my search. thanks
several companies make these - they're most prevalent in circle track racing - so any company that caters to the guys who go left have these.... this is just one for instance
Set toe last. It changes with camber/caster changes.
Mel, the VBP spec table is reporting total values: "For example, when we recommend 1/8" toe in, that indicates 1/16" on each front wheel for a total of 1/8" total toe in."
true, but if you've no experience with alignment, toe-in is an easy place to start.
