Higher volume oil pump for my solid roller lifters?
Old Sep 11, 2012 | 09:04 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Use a roller cam designed for the street and you shouldn't have any problems, these are solid rollers with less than #200 on the seat, you start getting silly running race rollers on the street you need the best stuff and even then they won't last. You can make 650-700hp with a big inch small block with a street roller and melling pump with 10% more pressure and it will last.
I got 20,000 miles on the old CC non pressurized solid roller 818's, with .600+" lift, revved it at the lights to splash them.
Old Sep 11, 2012 | 09:19 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Read Smokey's Power Secrets.
I didn't come here to get "rowdy" or talk/argue cams. Just wanted to pass something on that i thought matched your question. Well if your truly interested it is only 2 pages in the back of "Power Secrets".
Old Sep 11, 2012 | 09:32 PM
brando1118's Avatar
brando1118
Thanks Motorhead and Cardo0,
Well hell, all the rowdy ones have come to join the thread so I might as well give all you guys some cam and valve spring specs too....
Cam is a custom grind from Comp Cams:
Hot Valve Adjustment: Intake .016 and Exhaus: .016
Gross Valve Lift: Intake .571 and Exhaust .577
Duration @.50 Intake 242 Exhaust 248
Lobe Lift Intake .3810 and Exhaust .3850
Lobe Separation: 112.0
Valve Springs are Comp Cams CCA-938-16
Dual springs, damper included 480 lbs./in
Old Sep 11, 2012 | 10:54 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
That is a tight lash street roller. Your existing pump is fine. I agree that the 15W-50 or 20W-50 is too thick. A good 10W-40 is the heaviest oil you would need. The lifters are mainly lubricated by splash, It also cools the parts. A thinner oil will cool the internals better and spash more on the lobes, better lubrication and cooling of the internals. On a solid roller I would use a High ZDDP oil.
Old Sep 12, 2012 | 02:34 PM
Belgian1979vette's Avatar
Belgian1979vette
Originally Posted by 540 RAT
Jim is absolutely correct about the RPM trick only being intended for the early style unpressurized lifters. Plus, that was outdated thinking anyway, from when people did not know why those lifters failed so much. They were not pressurized, so people just assumed that was the cause of those failures. But, that was not the case, because now we know why they fail. More on that below.
So, you don't need to be concerned about oil pressure for your lifters. Keep in mind that needle bearings by design, are a very low friction bearing style that does not even require a ton of oil in the first place.
A plain bearing like is used in rods, mains, or bushing type solid roller lifters, do need a lot of oil to stay happy. But, a needle bearing rolls, it does NOT slide (unless it has a flattened needle or needles that won't roll normally), so little oil is actually needed.
As an example, two stoke motorcycles always use needle bearings at the small end and at the big end of their rods, just for that reason. The only oil they ever see is the oil that is mixed in with the gas, typically at a 20 to 1 ratio (20 parts fuel to 1 part oil) or even less oil. And those engines typically make way more HP per cubic inch than our stuff ever will. Bottom line, don't lose any sleep about getting oil to your needle lifters.
I did extensive research and a root cause failure analysis on BBC solid roller lifter failures. The conclusion was quite clear, every failed lifter I examined had failed from metal surface fatique failure, which has absolutely nothing to do with oiling. None of those failed lifters showed any signs at all of an oiling issue.
So, any worries you have about those lifters failing is related to the basic nature of the solid roller needle lifters being a poor design for what they are subjected to. Those little needles, only three are carrying the entire load at any given instant, simply cannot stand up to the constant pounding they see. It does not make any difference how well the cam's opening/closing ramps are designed, because the lash slop allows the lifters to bounce around within that slop. So, they see repeated jack hammer loading until they fail from that fatigue failure. It is not unusual at all for them to fail by 5,000 miles or even less.
If you ever decide you want to or need to replace those lifters, next time go for a set of the bushing type solid roller lifters. Because they have a 350% higher load rating than the needle type. And their bushings can stand up to the pounding far better than the needles. Isky has them as well as Crower.
As for running 15W50 motor oil, you may want to re-think that. Because that is way too thick for most any engine. You should never need to run an oil thicker than some type of 30 weight. You don't want to see a lot of oil pressure just for the sake of oil pressure. Because pressure is only a measurement of resistance to flow. And flow is lubrication and cooling. An engine's internal components are directly oil cooled, but only indirectly water cooled. Thinner oil will flow better/quicker to lubricate and cool better/quicker. And during cold start-up where most wear takes place, thinner oil will get to all the parts much quicker.
540 RAT
Member SAE (Society of Automotive Engineers)
540 you should remember the discussion on speedtalk, which didn't give a final conclusion about that.
When looking back on my build, i'm sure that the way the rocker system works on chevy systems (not shaft rockers) + way to much clearance at the lifter bores, offset valves, revkits and more all come into play when you consider roller lifters going bad. It's far to simple to just say that the pressurized oiling alone is the explanation.
Old Sep 12, 2012 | 02:38 PM
Belgian1979vette
Thanks 540 Rat,
I'm hoping that the milder spring pressure of my motor will help lessen the affect of the hammering you describe. I'd like to get more than 5k miles out of this set of lifters. But I will go with a bushing type lifter next time. But I see that I will have to make some changes to my oil pressure if I decide to run the bushing type solid rollers. You state that they need a lot of oil and I'm assuming that you mean more than my 20 psi at idle. From what I've learned here in this thread that is only happening with a higher volume oil pump. So I'll drive the car and have fun and yank the covers and check the lash regularly and.......pray a little.
This thread has been a learning experience. Thanks to all that have contributed.
A roller lifter can get more damaged by too little than too much pressures. You should go with what your camcompany recommends and install them in the proper way.
Old Sep 12, 2012 | 02:41 PM
Belgian1979vette
Depends on how wild the cam is. Mine has the same duration thighter LSA and 240 on the seat, 575 over the nose. After a lot of info, my cam producer, who is one of the best in the US and made a custom cam for me, said that the seat is the more important.
Old Sep 12, 2012 | 03:26 PM
cv67's Avatar
cv67
St. Jude Donor '05
I am no expert but would have to agree. IMo its the pounding those needle bearings and rollers, valve tips take, how is some oil going to cushion hundreds of psi it cant unless its a hydraulic. Idle mine about 1200 non pressurized Crowers. If I stay solid next time around then Ill get the bushed type that dont use them at all.
As Chris said once you stray from stock all bets are off hope for the best expect the worst. Set aside some just in case $ and beat the pants off it in the meantime
